Old 03-27-2008, 05:50 PM   #16
Car: 06 Subaru WRX STi
Fav Mod: Valentine 1
Send a message via AIM to shan mann
Default Re: How to - Install the AUX Board!
im doing my install right now and i cant seem to get it to work! this thing is making me go crazy!
i think i might have damaged my jazzy aux wire that is used to split the 2 units...
shan mann is offline   Reply With Quote
Old 03-27-2008, 06:09 PM   #17
Iron Fisted
Fav Mod: Sparco seat
how did you damage it? any pics?
Old 03-27-2008, 06:23 PM   #18
no im just putting it all back together.. ill try to take a pic of the flex cable..
i counted 14 gold lines on the stock headunit flex cable and 15 on the jazzy flex cable.. it doesnt fit into the stock location..
i think i just need a new cable
Old 03-27-2008, 06:53 PM   #19
Car: 2005 PSM STi!!!11
When I installed my board, I put the whole thing together and plugged it in and nothing happened. I thought I damaged something, so I just went back up to my room and took it apart, made sure all the wires were in place, and put it back together again. I didn't think it would do anything, because I didn't do much, but when I plugged it in, it worked!
But you probably already tried this, haven't you?
ZondaF is offline   Reply With Quote
Old 03-27-2008, 07:36 PM   #20
^ yep like 4 times already...
i cant seem to think im doing anything wrong. ive emailed jazzy inquiring about the ribbon cable.. the pro kit comes with a 3" cable.. mine is like 7.. and it doesnt fit into the stock location
Old 03-27-2008, 07:44 PM   #21
Oh, I see.
Are you sure that you selected the proper vehicle when you bought that board? The default setting is for 04/05/06 Legacy/Outback. You have to change it to 05/06 Impreza/WRX/OBS/Forester/Baja.
I almost bought the one for the Legacy/Outback but I realized it before I completed my order.
Old 03-28-2008, 06:07 AM   #22
i have also noticed that in the pictures above the aux board has the connections for both patch ribbons facing upwards.. mine has one facing upwards and one facing sidways
and could i connect the GLI to the aux board then connect the GLI to my ipod cable?
Old 04-11-2008, 02:07 PM   #23
Car: CGM 05
Fav Mod: IAG 38mm EWG
Send a message via AIM to 1loudsti
just installed mine, works awesome! i dont have the ground loop thing but i dont have a problem with noise...where did you ground yours to?
another minor thing...on an 05 sti the changer actually comes out the top
1loudsti is offline   Reply With Quote
Old 04-11-2008, 02:37 PM   #24
i sent my unit out to jazzy and there sending in a new aux board and cable.
ill install as soon as it arrives and update with the whole status
CDs FTL
