Old 07-28-2006, 07:52 PM   #46
Car: 2oo5 cgm STi
Originally Posted by rydeordie
How long does this whole procedure take w/out airtools and a lift. Will I also need a torque wrench for this job?
Yes you need a torque wrench if you want to get things back together properly. And for your first time def. give it more than 3 hours.
Old 07-29-2006, 07:29 PM   #47
Car: 04 JBP STI
Fav Mod: Anything i put on my car!!!
i dont know
i have installed alot of suspensions setups on numerous cars
it took me from 930 am to about 3pm
i did take about 1-2 hrs just hunting around town for certain tools that i had broke during installation also
the hardest part was breaking the bolts loose
get a good breaker bar and some extra adapters if necessary
i went through several adapters
NCWSTi is offline   Reply With Quote
Old 09-19-2006, 06:19 AM   #48
Car: 04 Silver Subaru Wrx
Fav Mod: Tein Flex coilovers
this might be a noob question but does putting on these springs void our warranties.
Young Sti is offline   Reply With Quote
Old 09-19-2006, 06:54 AM   #49
Car: 2oo5 cgm STi
^^^ don't expect Subaru to replace your struts if they start clunking, but it shouldn't affect anything else.
Old 10-09-2006, 02:59 PM   #50
Fav Mod: Tank the Terrier!
Send a message via MSN to RAPTR
I'm sure I'm repeating someone else but after this proceedure is finished, do you need to go and get an alignment done?
RAPTR is offline   Reply With Quote
Old 10-09-2006, 03:44 PM   #51
Car: Bugeyes forever!
Definitely get an alignment when you are done. The springs will settle a litlle after driving on the a while so if you can get the camber close by eyeballing it during reinstallation you can put it off until they settle and not hav to get another alignment if they settle too much.
Ver7wannabe is offline   Reply With Quote
Old 10-22-2006, 10:16 AM   #52
I just stripped the threads off of a lower strut bolt- the one that adjusts camber. I was trying to torque it to 140ft-lbs, just a smidge over the spec published in this thread, and it never came. Now the nut won't come off, it just spins (with some resistance).
I guess the recommendation to replaces these bolts every time they're removed might have some validity.
stretch is online now   Reply With Quote
Old 11-05-2006, 04:27 PM   #53
Car: shirokuro 06 STI
Send a message via AIM to b0oSt1N_LrG
one question... i don't know how you're supposed to take this nut off if i'm using hand tools... i thought this is where i use the wrench and the allen key, but how do i get the wrench to hold on to the nut? it's inside the upper mount...
b0oSt1N_LrG is offline   Reply With Quote
Old 11-06-2006, 03:00 AM   #54
Car: 08 STi, SSM
pass-through wrench like a Gear Wrench.
Old 11-06-2006, 03:24 AM   #55
Car: Waiting for the STI
Fav Mod: Driving My Car
Yes, something like this
http://www.sears.com/sr/javasr/produ...seBVCookie=Yes
sebtarta is offline   Reply With Quote
Old 11-06-2006, 01:49 PM   #56
ahh icic... back to work then ;]
thnx guys
Old 11-06-2006, 03:15 PM   #57
Car: 06 CGM/silver STI
Fav Mod: DIY modding
Anyone suggest an affordable compressor and air gun?
FleaDog is offline   Reply With Quote
Old 11-07-2006, 03:07 AM   #58
Go by sears, they have some pretty good ones for $100 and then a gun set for $75
Its about that, you could spend $300 and you should have a very nice setup
Old 12-13-2006, 07:34 AM   #59
Car: 05 white STi
Fav Mod: audio
just curious, does anyone have tips for putting the stock strut/springs back on? I have my coilovers on now, but am selling the car soon. the problem i keep running into is that it appears that my stock front struts are 5" too long to line up with the hub...no matter what kind of brutalizing i do.
so now i'm kinda lost O_o. the bottom of the stock strut is pretty much on the CV, to give you an idea of length. If i could get a tip to get around that one bit, that would rock, as i really, really don't want to spend a few hundred dollars having someone else do it
jsmonet is offline   Reply With Quote
Old 12-13-2006, 03:48 PM   #60
Dp yopu have the full front end up on the air? It might be that the sway is putting some load from the other side preventing you to be able to match the strut with the hub.
