Old 06-01-2006, 07:59 AM   #16
Car: 2005 STi
Fav Mod: Stage dos.
Originally Posted by IUSTi
how long does this install usually take with 2 people and no air gun?
depends if you run into stupid problems along the way .... it took "straightouttajersey" and I awhile to do it. Only because we are weak. It woulda taken much longer without the airgun.
We started at like 7:15... had to get the car up on jacks etc. etc. we were done around 12:30. We mostly just wanted to make sure everything was compressedd right on the spring and all that good stuff. And we screwed up a few times, so it took wayyyyyyyyyyyy to long.
609Audio is offline   Reply With Quote
Old 06-01-2006, 08:16 AM   #17
Car: 05 Subaru WRX STi
Fav Mod: Bilstein PSS9 Coilvers
Send a message via AIM to IUSTi
7:15 am to 12:30 at night?
IUSTi is offline   Reply With Quote
Old 06-01-2006, 10:26 AM   #18
Car: 2005 STi
Fav Mod: Stage dos.
lol no
7:15pm - 12:30 am
Old 06-01-2006, 10:35 AM   #19
Send a message via AIM to straightouttajersey
the hardest part it seemed was getting out the stupid slider tab that holds the brakeline to the rear strut. I dont remember it ever taking that long when we put the springs on my car...
straightouttajersey is offline   Reply With Quote
Old 06-01-2006, 04:03 PM   #20
Car: 2005 STi
Fav Mod: Stage dos.
yeah dude i think i broke a testicle, pulling so hard....
Old 06-01-2006, 06:19 PM   #21
Car: 2oo5 cgm STi
the hardest part it seemed was getting out the stupid slider tab that holds the brakeline to the rear strut...
Flathead screwdriver from below, pointy end where the tab bends, tap the handle with a hammer, pops right off. Hard to describe, I'll take some pictures if I can ever find some $%&*& PDE plates to do my next install.
Old 06-02-2006, 03:37 PM   #22
Fav Mod: Suspension
Send a message via MSN to Sunfighter
Hey guys, ignore me if this is a dumb question since I haven't really looked at them yet, but is there any useful direction/guide out there for removing the rear seats for a spring install? Thanks as always.
Sunfighter is offline   Reply With Quote
Old 06-02-2006, 07:25 PM   #23
the rear seat is really easy to take off, you just look at the bottom of the cushion and you'll see two hook like things, you have to take the plastic thing off of them and then unhook the hooks. Its almost self explanatory i did it once without even knowing what i was doing. you cant mess it up
Old 06-03-2006, 04:05 PM   #24
Fav Mod: Suspension
Thanks dude!!! Much appreciated!
Old 06-03-2006, 04:11 PM   #25
wdb
dances with roads
Two bolts that hold the bottom cushion are exosed plain as day on the vertical face below the front edge of the cushion. Take them out, pull the bottom cushion out, and you will see the 3 bolts that hold the backrest. Take them out, lift the backrest straight up to unhook it at the top, and shazam.
As always, "Installation is the reverse of removal".
Old 06-28-2006, 08:18 AM   #26
Car: 05 STi OBP
Used this thread this morning to install my Prodrives.
Thanks for the write-up !!!!!!
gslben is offline   Reply With Quote
Old 07-02-2006, 08:59 PM   #27
Great write up, question on 2 torque values. The 17mm that seperates the top hat from the spring and the 14mm bolt in the front springs that allows you to modify the bump stops.
Also an observation if you look at the bumpstops they are "glossy" almost like a coating is applied. When you make a cut it's dull maybe slightly porous. Anyone know if this has a negative effect on the bumpstop life? Thanks!
Shomen is offline   Reply With Quote
Old 07-03-2006, 04:23 AM   #28
Car: 06 WRB GOLD STI
Fav Mod: DDX7017
Very nice write up! Will be doing this mod soon enough
Old 07-05-2006, 01:50 AM   #29
TRM
i am Darwin's rottweiler.
Fav Mod: Driving Lessons
Send a message via Yahoo to TRM
it should not. the gloss effect you are seeing is a characteristic of how they are manufactured. the material is poured into a mold to cure and dry. the mold is smooth for easy removal of the bump stop, thus it will give a glossy finish to the touching surfaces.
TRM is offline   Reply With Quote
Old 07-05-2006, 07:34 AM   #30
Fav Mod: Perrin 30r Kit
good writeup. used it yesterday to put in my gf210's.
XxSCAxX is online now   Reply With Quote
