Old 05-17-2006, 09:04 PM   #16
Poor Speed Racer
Car: 96 328
Alright guys, here is the after math
Thats the drivers side hose and after 300+ miles of track (3 days baby!) and 40-80 miles of street driving (thanks to a broken radiator hose) this is how it looked. Clearly the hose is spent, but it was nice to use it as a turn in trigger as it rubbed on the track in turn 3
but this is the passenger side hose
as you can see, there is NO damage at ALL, so I will be reusing this hose
so I think I'm going to press the hose into an oval the next time. But I'm really impressed with the hose, i mean, it went thought HELL!!! that I"m sure on the track it would have been fine.
Old 05-22-2006, 03:58 PM   #17
Poor Speed Racer
Car: 96 328
w00t for the how to section!
Old 05-29-2006, 01:16 PM   #18
Send a message via AIM to rev_happy_sti
is that the best place to put the hoses so they get air? wouldnt it be better to route it somewhere in the front of the car?
rev_happy_sti is offline   Reply With Quote
Old 06-09-2006, 11:56 AM   #19
Car: 05 STi, CGM
Fav Mod: PF 01 pads for the track
Thanks for all the great write up and hints for those of us who just purchased a set. Just FYI: The guy at RCE said that they give out 12' of hose now, I havent recieved them yet so I will let you know when I do.
F
STi-FLASH is offline   Reply With Quote
Old 06-19-2006, 06:09 PM   #20
Sold My Soul For Mods
Car: '05 CGM STi
Fav Mod: Track Time
Trader Rating: (14)
Here are some pics of my Kool Brake Kit install. This really helped in keeping rotor temps down, I had no fade whatsoever and VIR is a very high speed/heavy braking track. I'd recommend them to anyone who tracks their car.
Inlets courtesy of Home Depot Racing They look ghetto but they worked very well. I just used some dryer duct reducers and cut them to fit my JDM fog surrounds.
I routed the ducts in the most simple way possible, while also trying to maintain as much ground clearance as I could. I ended up with no scraping on the ground and minimal rubbing of the tire on the ducts at full lock (only happened driving around the paddock at low speed).
Old 06-20-2006, 09:45 PM   #21
Do you have any pic's of where you ran the hoses to get to the back of the fog light surrounds? Did you cut through the inner fender?
Enchanter is offline   Reply With Quote
Old 06-22-2006, 07:30 AM   #22
Poor Speed Racer
Car: 96 328
no he didnt cut the fenders at all, he simply pushed that piece that extends from the fender well onto the front mud sheild (they are failry small pieces) and routed the hose through there if i understand correctly.
EDIT:
There is a piece like this on the 04-05's that you can push up, and route them though there
Old 06-22-2006, 08:56 AM   #23
Car: 06 B-SPEC Legacy wit
Fav Mod: AP Pedals and Motons
Send a message via AIM to GTWORX.com
Yep, no cutting at all. I just pushed the plastic sheild in front of the fender lining aside and squeezed the hose through there.
-Dan
GTWORX.com is offline   Reply With Quote
Old 07-26-2006, 05:26 PM   #24
Car: 05 STi OBP
Fav Mod: Data Acq System
Where can I buy some of this hose?? I track my car and right now I am so pi%$ed off at the brakes it is not even funny. They get sooooooooo hot it is not even funny.
MGizzle is offline   Reply With Quote
Old 07-31-2006, 02:04 PM   #25
Just give us a call.
Old 11-15-2006, 03:36 PM   #26
Car: 05 WRB w/Gold
I bought the 6$ air pleeps /plaps (as subaru calls them) to complete the start of the factory air ducts . haven't bought the little clips / (plastic screw nail type things that holds the fender liners in)
it creates a high pressure zone up there. esp if you add a front lip spoiler so assuming i ever finish it off it should help for my track days.
A1337STI is offline   Reply With Quote
Old 05-27-2007, 06:00 PM   #27
Car: Black 05 STI
Fav Mod: Driver Upgrade
Default Re: How to - RCE Kool Brake Kit
I just added a post for installing the Kool Brake Kit and keeping the rotor heat shields in place. I had to modify the shields. Pics are posted here:
Kool Brake Kit : Heat Shield Mod
jared57 is offline   Reply With Quote
