Old 07-30-2007, 09:02 AM   #31
Fav Mod: nothing significant yet
Default Re: Worx Tuning Sway Bar Install How-To
Other posts have talked about making sure that the bolts are torqued to spec. What are those specs?
Grog The Red is offline   Reply With Quote
Old 07-30-2007, 09:05 AM   #32
Ahhh. Never Mind I saw them now.
Old 09-14-2007, 03:09 PM   #33
Fav Mod: Whiteline Sways
I felt comfortable about this install going into the project, but I've hit a wall. Hopefully someone can shed some light on my problem. I plan on using the stock rear endlinks and mounts with a 24 mm Whiteline bar. My problem is that all four 14mm endlink nuts are spinning with the bolt. I soaked with PB Blaster. Even if I could vise-grip the bolt, how would I tighten it after the switch? I removed the fronts with ease. I see no indication of a bolt head or place to hold the bolt to keep it from spinning. Any ideas would be appreciated.
Under_control is offline   Reply With Quote
Old 11-08-2007, 01:26 PM   #34
Car: 05 CGM STI
Fav Mod: Being Unbeatable
Hey JPW ERASER...where did u get that spoiler with the carbon fiber?
zim2322 is offline   Reply With Quote
Old 03-30-2008, 09:18 AM   #35
Car: 2005 Subaru WRX STi
Fav Mod: APS TBE
On this install... how much angle is too much on the endlinks when doing a bar/link/mount install? I have my rear ones (Perrin) have a bit of an angle pointing drivers side is L-to-R and passenger side R-to-L but want to make sure.
weakness is offline   Reply With Quote
Old 05-13-2008, 03:51 PM   #36
I'm having problems taking off the stock sway. I got all the bolts except the passenger mount, the one where it is RIGHt between these two fat metal bars, with the heat shield. I even tried taking the heat shield off, but stupid Hme stripped the bolt pretty bad, though I did also strip the main bolt a bit, but if I could get full leverage, I could probably take it off. How did you guys handle this? and no I refuse to accept time and patience as an answer
empfl is offline   Reply With Quote
Old 05-15-2008, 11:36 AM   #37
anybody?
Old 07-14-2008, 05:26 AM   #38
Car: 07 STi
Fav Mod: rear window bling
Can anyone provide the part number for a rear sway bar mount? I managed to break mine this weekend. SubaruGenuineParts.com has a rear sway bar mount for the 'impreza model'. Will this fit the STi?
Would an aftermarket mount be a better route? Whiteline offers a bracket specifically designed for the 24mm Sway Bars that looks beefy. Can I expect any significant increase in performance (if at all)?
If anyone has the aftermarket mounts, could you tell me if the stock sway would fit on those mounts as well?
asdfghjklvt is offline   Reply With Quote
