| Home | Register | Today's Posts | Go Premium | New Posts | | Mark Forums Read | Create a Member Journal | Marketplace |
| | #31 |
| Moderator Feedback Score: 34 reviews |
__________________ 2005 Obsidian Black Pearl STi/Gold BBS 2002 Midnight Black Pearl WRX 1986 Black Chevy Camaro Waiting to be Installled: A ton of parts! On Order: My Journal JDM Ballers Club Member #6 403whp & 461wtq in 5th gear (Est now 440whp) Tuned by Chris @ EFI Logics |
| | #32 |
| Junior STI Driver Feedback Score: 0 reviews Join Date: Sep 2005 Location: Where am I ???
| I need to get this thanks for the reminder Ben
__________________ On the road of life there are many right and wrong turns, but in the end it is only up to you that you have taken the right path!!! |
| | #33 | |
| Retired Admin Feedback Score: 13 reviews | Quote:
TBE install could be coming as well.
__________________ Ben Fried RealityDesign - 2008 Silver BMW 135i - 2010 Team RD #027 Lotus 2-Eleven Race Car | |
| | #34 |
| Spec C Club Feedback Score: 0 reviews Join Date: Dec 2005 Location: Fitchburg, MA
| HSPN>* That is all..
__________________ |
| | #35 | |
| Professional STI Racer Feedback Score: 2 reviews Join Date: May 2003 Location: Chester Springs, PA
| Quote:
__________________ 2004 Silver/Silver STi JDM Pinks, carputer, Crucial Racing DP and Catted Midpipe, Maddad Whisper catback, Whiteline f/r sways, CL X-Brace, RPS Street Max Clutch, Perrin Wing Stabilizers, TiC Fender Braces, V-Limited Lip, Bridgestone RE01Rs. Protune #2 by Agile 330 whp @ 20psi 350 wtq | |
| | #36 |
| Immoderate Feedback Score: 8 reviews Join Date: Apr 2005
| 1. I have not seen this anywhere else; it is not in the install video, and it is not in the Cobb installation instructions. Given all of the "my reverse lockout rattles after my short shifter install" threads, I strongly recommend that this be done. After the stock shifter is out of the car and while in the process of swapping parts over from the stock shifter to the Cobb unit, there is a soft rubber seat for the reverse lockout spring that should be moved over with the rest of the parts. The seat is located just above the round plate that the screws go through to hold the silver shift boot mount. 2. When securing the reverse lockout cable under the car, I recommend the following steps to ensure that the cable is clear of the driveshaft in all conditions:
Pictures below show the reverse lockout spring seat still on the stock shifter, the seat itself, and the seat installed on the Cobb lever. Also one pic of the cable, guide and tie wrap as I arranged them.
__________________ -wdb 2005 CGM STi: Defi BF V-Limited 'cleared' trunklid Mines replica Prodrive/Group N rear foglight Cobb SS Hotchkis Sways Ferodo-DBA-Technafit-ATE Last edited by wdb; 05-22-2006 at 12:53 PM. |
| | #37 |
| Amateur STI Driver Feedback Score: 0 reviews Join Date: Oct 2005
| Thanks a lot Ben, I don't think I could have done it without the video or at least done it as fast. Thanks
| | #38 |
| Retired Admin Feedback Score: 13 reviews | You're welcome!
| | #39 |
| DOMINATOR Feedback Score: 5 reviews Join Date: May 2005 Location: STL
| Ya, thanks for the vid Ben...and thanks to wdb for the tip dealing with the reverse lockout. I'll probably be ordering this soon.
__________________ 2005 STi - OBP Power: 380whp/400wtq Dominator 1.0 + DR525 + 44mm EWG = |
| | #40 |
| Senior STI Driver Feedback Score: 0 reviews Join Date: Apr 2006 Location: Atlanta, GA
| I installed the Cobb short shifter in my 04 STi following the video. The video was very helpful, the only problem i had was with that stupid reverse lockout pin. It was a major PITA to get out of the stock shifter and back in the short shifter. Anyway, what I want to add to this thread is about that metal plate that you are supposed to cut the corner out of. If you have an 04, instead of cutting the corner out of the metal trim plate, you can simply rotate the piece of metal 180 degrees and screw it back on. This will put the extra corner piece towards the rear of the car and out of the way of the linkage. There are 2 little tabs of metal sticking out of the bottom of the plate (original bottom), that when rotated you will need to bend about 45 degrees to get it to fit right. So, take it off, bend those tabs up a bit, rotate 180 degrees, screw back on. Done, make the throw as short as you want. I don't think this works on 05/06 b/c I think the plate is shaped differently and can't be rotated. I wanted to add this in here b/c i skipped the cutting of the plate b/c I was lazy, and that left me with not very short shifts, and a shifter that was sticking way back from the stock position and banging on my center console trim. |
| Thread Tools | |
