Old 03-03-2006, 12:27 PM   #16
Fav Mod: FYI, I'm a dude
Originally Posted by Nivek
Just an FYI, based on watching this video, installing this shifter is 10x easier to install than the factory short shifter by STi. That things was a major PITA. This one looks like its slightly difficult, but no where near the difficulty of the STI one. Besides, the STI only gave me like 10% shorter shifts, whereas the Cobb one gives you alot more I am told. I cannot wait to test out the shifts and shorter throws.
Ben are the shifts crisper, smoother, jerkier, ... any info you can give would be awesome
yeah, the for anyone interested, the sti short shifter is much more difficult to install because it replaces your entire shifter assembly. the kartboy/cobb units are much easier to install because you're just replacing the lever. the install becomes more difficult, however, if one decides to add the front and rear shifter stay bushing, and shift linkage bushings from kartboy and tic. i would HIGHLY recommended adding these bushings if you're going to add the cobb or kartboy lever.
Old 03-03-2006, 03:50 PM   #17
Car: 2002 WRX Stg2
Fav Mod: External Wastegate
^^So with the STi shifter you wont have to get those extra bushings?
blk rex is offline   Reply With Quote
Old 03-03-2006, 11:56 PM   #18
www.Subie.tv is niiice
The STI shifter does not come with hardened bushings. You still need to add them if you want the effect they offer. I highly recommend doing everything at the same time; whatever short shifter you choose.
Old 03-04-2006, 09:53 AM   #19
so in conjunction with the Cobb Shifter what other hardened bushings would be recommended to install at the same time....can someone post up a link? I looked at TIC's website but they have like 13 different sets of bushings and it gets kinda confusing with all their "alliteration" I think it's funny but still makes it confusing.
2LTL2L8 is offline   Reply With Quote
Old 03-04-2006, 10:42 AM   #20
Nanned ®
Great video, a future project for me
Old 03-04-2006, 11:06 AM   #21
Car: 2002 WRX Stg2
Seriously its confusing as hell.
Old 03-04-2006, 11:30 AM   #22
lal
Car: 04 STi (sold)
Really excellent work Ben, informative and easy to understand, Thanks
lal is offline   Reply With Quote
Old 03-04-2006, 11:43 AM   #23
Ben
Retired Admin
Car: 2006 Audi S4
Fav Mod: Weight Loss
Send a message via AIM to Ben
Just get the Cobb bushings when your order the Cobb shifter. It only comes with the bushings you need, no confusion.
Ben is offline   Reply With Quote
Old 03-04-2006, 12:05 PM   #24
here you go fellas.
for 04-05 stis: http://turninconcepts.com/product_in...products_id=10
for 06 stis: http://turninconcepts.com/product_in...products_id=73
the only difference between the two is the 06 bushing bundle does not include the shift linkage bushings. the ones they currently have won't fit the 06 sti. tic is working on 06 shift linkage bushings.
Old 03-04-2006, 12:25 PM   #25
here's a tip that is not mentioned in the video. after you're done and you remove the allen wrench holding your reverse lock-out cable, take a zip tie and attach your reverse lock-out cable to the shifter stay above the drive shaft. make sure the cable does NOT rub the driveshaft. if you're using a shifter that is shorter in height, there will be more slack in the reverse lock-out cable than stock. this could result in the cable rubbing the drive shaft while you are driving if you don't zip tie the cable. this happened to me and resulted in a shredded cable sheath, cable, and a driveshaft that is missing the protective coating where it was rubbing.
kevin
Old 03-06-2006, 02:25 PM   #26
Ben
Retired Admin
Car: 2006 Audi S4
I don't think the lockout cable could rub the driveshaft even at the lowest setting with this particular short shifter, but that that certainly can't hurt. Good tip.
Old 03-06-2006, 05:28 PM   #27
Car: 06 Aspen White STI
how do u cut that metal? my garage lacks the tools to do the install but i'm most worried about cutting the metal
CruisinSTI is offline   Reply With Quote
Old 03-06-2006, 07:09 PM   #28
Ben
Retired Admin
Car: 2006 Audi S4
Take it to any shop near you and have them cut it (takes 5 mins...most shops won't even charge you), or buy a reciprocating saw from Sears or any hardware store for about $70. You could also leave it as-is if you don't plan on making the throw SUPER short. The shorter the throw, the bigger that angle is and the closer the linkage gets to touching the metal trim.
Old 03-07-2006, 08:42 AM   #29
wdb
dances with roads
It definitely is a good tip. People with the Kartboy shift lever have had their reverse lockout cables ground to pieces because of this. IMO it should be thought of as an essential step.
Old 03-07-2006, 09:48 AM   #30
Car: 06 Subaru WRX STi
Fav Mod: My right foot...
So the Cobb shifter is better than the Kartboy with TiC bushings? I know that the Cobb is adjustable but other than that what are the pros or cos compared to the Kartboy?
pantag is offline   Reply With Quote
