Old 05-23-2007, 05:57 AM   #106
Car: 04 WRX Wagon
Fav Mod: Deadbolt Super 16G
Default Re: How To: Automatic Intercooler Sprayer (boost referenced)
Originally Posted by MacSTi
I have it all hooked up right, I will update tomorrow on the results...
update please.
j*bishop is offline   Reply With Quote
Old 05-23-2007, 07:56 AM   #107
I has BOOST!
Fav Mod: LightWerkz Projector Retrofit
Trader Rating: (12)
Send a message via AIM to MacSTi
It works like a charm, but what I will have to do is get another T fitting because when I connected the DEFI boost gauge, I unplugged the stock one. So I plugged the stock hose back in and it works like a charm. I am going to home depot today to get another fitting.
MacSTi is offline   Reply With Quote
Old 05-26-2007, 06:58 AM   #108
Car: WRB 06 STI
I love this mod. I completed it in about 1 hour this morning, using a free sample pressure switch from the manufacturer. Easiest functional performance mod ever.
EESTI is offline   Reply With Quote
Old 05-26-2007, 05:30 PM   #109
Just did this myself today, since I have a defi boost, I had to fish the lines through to the engine bay. but everything worked great!
Thanks WolfPlayer!
KrazyKarl is offline   Reply With Quote
Old 02-03-2008, 12:38 PM   #110
Car: Black 06 WRX STi
Fav Mod: Stage 2 is GREEEAT
Where are you guys getting the JDM Auto Switch from? Is there a part# for it? I found a site that had it but it was $40.
xcritic is offline   Reply With Quote
Old 02-03-2008, 02:11 PM   #111
Car: 08 Gray STi
So the 08 STi owners, need to first retrofit an intercooler spray system and then do these mods to make it semi-auto?
Old 02-03-2008, 02:48 PM   #112
wdb
dances with roads
That's the going rate. SoJDM has it, and they're a vendor here:
http://www.sojdm.com/store/pc/viewPr...3&idproduct=15
Old 02-03-2008, 03:24 PM   #113
Car: '08 BMW 135i
Fav Mod: International Engine of the Year
Send a message via ICQ to jtsherri Send a message via AIM to jtsherri Send a message via MSN to jtsherri Send a message via Yahoo to jtsherri
FYI ~ I have both the JDM switch AND the eBay boost switch available for sale. I won't have the car back for a couple of more weeks (she's getting a new motor); however, I'm definitely parting it out and will cut a deal for both of them. For those interested, these two parts have never actually been "used" since I never finished wiring up the system. The JDM switch simply sits in the dash (with no wires) and the boost switch is sitting in series with the boost hose going to my boost gauge (also with no wires).
Generally you'd pay $52.00 (for the pair) + $11.50 shipping. I'd let both go for $45 shipped. PM me if-interested.
jtsherri is online now   Reply With Quote
Old 02-26-2008, 05:54 PM   #114
i did the install tonight and everything works great. However when the ignition is switched to acc. I can use the jdm switch to turn on and off my parking lights. Any idea why this would be? I followed the jdm wiring diagram on the first page and seemed to get it right. This is on a 06 sti
Old 02-26-2008, 06:18 PM   #115
Fav Mod: FYI, I'm a dude
recheck your wiring. something is not hooked up properly. i had the same issue too at first. i forget which wire was the problem though.
Old 03-04-2008, 02:25 PM   #116
Car: 05 STi CGM
Fav Mod: JDM Foglights
60 degrees out yesterday, flipped my switch to ON for boost activated spray and got nothing. Anybody have reliability/survivability issues with the boost switch? All my connections were sound before winter but I will double check...maybe the cold got to the switch...
SCOOBYTRAP is offline   Reply With Quote
Old 04-10-2008, 06:22 AM   #117
2 questions:
1. Is this the correct relay (2-24 psi): eBay Motors: Boost Pressure Switch - For Turbo Water Injection hobbs (item 330208763186 end time Apr-30-08 13:39:21 PDT)
2. What is the vacuum line diameter and will it connect w/o an adapter to the switch nipple?
Old 04-10-2008, 06:58 PM   #118
Car: 04 WRX Wagon
anyone in socal wanna help me out w/this?
Old 04-11-2008, 01:45 AM   #119
Car: 05 STi CGM
Originally Posted by boxtwo View Post
2 questions:
Yes, this should work. you will need a T fitting and possibly a reducer kit to fit it properly to stock lines (depends where you are tapping into). but a T fitting/reducer kit is cheap at Autozone.
Old 04-11-2008, 03:40 AM   #120
Got them....
