Old 10-31-2007, 07:40 PM   #196
Car: 06 Subaru WRX STi
Fav Mod: Valentine 1
Send a message via AIM to shan mann
Default Re: **DIY Hella Super Tones Install **
oh man i like literally just got these now and its 10.40pm and im soo anxious to get home from school tomm, go to autozone, get materials, and install...
but i dont know what i need lol!
shan mann is offline   Reply With Quote
Old 11-01-2007, 04:53 PM   #197
haha these things are awesome, just soo loud and look sick!
just grounded the 2 hellas, then connected the stock wires...
took 10 min
here are a couple pics
Old 11-02-2007, 04:13 AM   #198
ok so for some reason idk why but i started my car this morning to go to school.. and the steering wont work (it is very very hard to steer), the ebrake light stays on.. as well as the battery light.. anyone know why.. its very unsafe to drive and im kinda worried cause i dont know how im going to get it home??
someone please help
after i did the hella install i drive my car for a little and took some pics and everything was fine
y-day when i did the hella install i did the led parking light mod also..
please help!
Old 11-03-2007, 03:30 PM   #199
Car: 07 SWP STi
Fav Mod: Perrin Exhaust
great writeup, mine seem to be working.
Dragicon is offline   Reply With Quote
Old 05-18-2008, 07:49 AM   #200
Car: 2005 Aspen White STI
I bought a set of used Hella's and they didn't come with the relay. I contacted Hella and this is the realy part number they gave me. Found on ebay and some other online sites that you can google by the part number. Less than $8 for this part shipped.
H41510061 is the part number that you will need.
Just in case anyone needed one.
05aspenwhitesti_centralnj is offline   Reply With Quote
Old 05-19-2008, 05:32 PM   #201
Fav Mod: Gram Light 57F's
Send a message via AIM to jordanretro1223
That's awesome. I just did the same thing as you bought a used set without the relay. I just ordered my relay though, thanks for this part number.
jordanretro1223 is offline   Reply With Quote
Old 05-21-2008, 10:15 AM   #202
Fav Mod: Access Port V2
Just installed mine this morning before work. When to pepboys and got the supplies. Took me about an hour once i started. They look sick I must say. ***Do not stand infront of the car when you test them.
St-ill is offline   Reply With Quote
Old 05-22-2008, 04:06 PM   #203
Got my relay yesterday and installed the horns today. They are LOUD, haha.
Old 06-03-2008, 10:43 AM   #204
Fears smelly diff fluid
Fav Mod: Invidia G200
Did mine a few weekends ago... spray painted them Cherry Blossom Red
Old 06-03-2008, 11:33 AM   #205
Car: 2007 STI Limited
Fav Mod: Stage 2
Send a message via AIM to coop1103
When you install them in these locations...is it hard? I did not want to have a problem and wanted to have the install reall easy if I got these. What is invovled with the way you installed. I have heard when you put them in the stock horn locations they do not line up correctly.
coop1103 is offline   Reply With Quote
Old 06-03-2008, 11:55 AM   #206
Trust me.. you will have absolutely no problem installing them there. There are bolts for the radiator on either side of the hellas which made for perfect mounting location for this set-up (look closely at the left grill in the pic.. you can see the bolt through the grill). The stock horn location is not in the grill... and not even symmetrical; they sit down low in front of the radiator with one horn in the center, and one horn off to the right of the radiator
You will have to remove the inner plastic covers from the two side grills if you do end up mounting them there... that basically requires you to remove 3 small screws and then unclip the cover, so no worries there!
This is probably the easiest way to install hellas on the 06/07
Old 07-23-2008, 10:01 AM   #207
Car: DGM 2008 STI
Fav Mod: 292 WHP!! 352 TQ!! RaWr
Hey im really confused with this... Some say you use the stock wiring while others say you need new wiring... so which is it?? ANd the materials is that what he has listed on the first page, and you can get at any autozone store? Thanks in advance
Old 08-07-2008, 06:37 PM   #208
Car: SWP 07 WRX STi
I used the same connections from the stock ones without any of those relays. Took me about 10 mins to install. Thanks to the guy above me for the idea of mounting it to the radiator~!!!
Here's what mine looks like, Satin White Pearl with RA-R grill mod and homemade license plate delete. Enjoy!
sti2oo7 is offline   Reply With Quote
Old 08-08-2008, 02:52 AM   #209
Nothing wrong with using the stock wiring. Only difference is that they are about 3 times as quite as they would be with the relay. Otherwise, they still function as a horn.
Old 08-16-2008, 09:01 PM   #210
subscribed...
zeenon53 is offline   Reply With Quote
