Old 06-05-2007, 03:25 PM   #181
Car: 2007 OBP/Gold Wheels
Fav Mod: Prodrive Mudflaps
Default Re: **DIY Hella Super Tones Install **
Originally Posted by LightWerkz
That is the wierdest sounding horn I haver ever heard. It sounds like a laser beam from star trek!
Old 06-05-2007, 05:20 PM   #182
Welcome to The Board
Car: 06 WRB STI
Fav Mod: Advan RS
Send a message via ICQ to Ikon Send a message via AIM to Ikon Send a message via Yahoo to Ikon
Originally Posted by slyguySTI
thanks for that 06 DIY, and is there anyway to get them next to each other so they arent off looking? thanks
look on the first page.. i shown a few pictures.
Old 06-05-2007, 05:23 PM   #183
Car: 06 WRB STI
Fav Mod: Advan RS
Originally Posted by S D M F
from what i read, your not using the hella relay?? if so your probably pulling too much current. if all your connections are good, im gonna say that your pulling too much current thru the stock wiring. i think the stock wiring is 18 AWG or possibly 16 AWG. I suggest a re-wire using the hella relay, and 14 AWG wire like the DIY says. check your grounds too. not to make you sound dumb, but fuses blow so that dangerous amp levels wont screw up the equipment.
P.S. Whats the fuse size for the horns anyway?
it dont matter if you use the relay or not. relay is just to make it slightly louder. so there is no way you can blow the oem fuse unless you wire it wrong. try making sure you have a good ground i had the same problem at one point. stock wire is 14 gauge i think.
Old 06-05-2007, 05:26 PM   #184
Car: 06 WRB STI
Fav Mod: Advan RS
Originally Posted by H4N
no i'm using the hella relay, and my set-up is exactly like the write-up. And inline fuse i wired up didnt blow only, the OEM fuse the (small 15amp). The inline fuse i have a big 20amp. And i know the purpose of fuses, that the thing that gets me they worked fine for about 2 weeks and now i dont know whats wrong.
i'm going recheck my grounds again.
i had the same problem as you easiest way to check. when you arm your alarm does the light blink and no horn ring right. if that is the cause your ground is bad. there is no way you can blow anything i am unsing a line 20amp also . read my DIY again and you should get it to work
Old 06-05-2007, 05:28 PM   #185
Car: 06 WRB STI
Fav Mod: Advan RS
BTWif anyone needs pictures of anything i can post or where are good grounds and all..
Old 06-07-2007, 12:42 PM   #186
Car: 05 OBP STi
Fav Mod: B&B Exhaust
Just installed mine and I love them! Thanks for the write-up.
xnthuzst is offline   Reply With Quote
Old 06-10-2007, 04:14 PM   #187
Car: 2007 Limited STI
Fav Mod: widebody
ahaahahha yea seriously
Josh[ua] is offline   Reply With Quote
Old 06-28-2007, 01:08 PM   #188
Car: 06 Subaru WRX STi
Fav Mod: HKS SSQ BOV
Send a message via AIM to SENSEIMACK Send a message via MSN to SENSEIMACK
I have an 06, and is there any one close to NJ, East Orange, Bloomfield, Newark area who can help me with the install?
Also does it really matter if you use the existing horn wiring?
Will it give the same voltage?
What if i wanted to have all horns working at the same time, is this unnessary? is it Counter-productive as far as voltage, freqency, etc?
SENSEIMACK is offline   Reply With Quote
Old 06-28-2007, 02:12 PM   #189
Car: 06 STI
Fav Mod: Your MOM!!
hey ceas thanks for the great write up, i did a couple things different though, i just made all my wires and kind of eyeballed the lengths and connected everything to the relay and put all the grease on and covered everything with wire loom and heat shrinked and electrical taped everything, then when i go to install i will just have to unhook stock horn wire and mount the horns and screw in the pos and ground wires and done... great write up BTW
EDIT: i know the directions say and you say to use the same ground location as the horns mounting bracket, but i just fabbed up another wire the same as the positive wires and ran it back to the stock grounding location, havent check if it works yet considering i havent installed them, but if it does i think it might look cleaner maybe, who knows maybe im just a lil too anal..
Old 07-16-2007, 11:09 AM   #190
Car: WR Blue 02 STi
Bit of a random question this maybe..
Do US spec Imprezas have a power-steering cooler in front of the Rad like UK/Euro/Jap spec Imprezas do? If so, what have you done with it?
I've seen these horns of a couple of US "show-car" imprezas and think they look great, even though they're only made in Germany they're rarer than rocking-horse ..... over here; I'd love a set, but dont see a way around the power steering cooler
Prasius is offline   Reply With Quote
Old 08-07-2007, 04:31 PM   #191
Car: 06 STI
Fav Mod: Your MOM!!
no i dont think we have a power steering cooler at all, especially in the location of the UK version STI
Old 10-31-2007, 07:10 PM   #192
Fav Mod: Valentine 1
Send a message via AIM to shan mann
just got my supertones in today.. and ive read many pages in this forum but i cant seem to understand the install!!
what additionals must i purchase in order to install these horns?
can i just tap into the stock horns and ground the hellas?
shan mann is offline   Reply With Quote
Old 10-31-2007, 07:12 PM   #193
Car: 04 WRX Wagon
Fav Mod: Deadbolt Super 16G
that's what i did.
j*bishop is offline   Reply With Quote
Old 10-31-2007, 07:13 PM   #194
do i need to purchase any thing else?
other than the wire? what gauge wire tho?
Old 10-31-2007, 07:24 PM   #195
Car: 04 WRX Wagon
i know i didn't. i forgot what gauge wire though. it's been a while.
