Old 02-02-2007, 06:42 PM   #151
Car: 07 WRB STI
These look great, but blocking a "Hella" lot of air flow really isn't worth a loud horn.. I think mounting them in an alterative area would be the way to go.
motoiq_young is offline   Reply With Quote
Old 02-02-2007, 07:57 PM   #152
Car: 06 AW STI
Fav Mod: Hardwired 8500
true it does block air flow, not a problem in 6 degree CO right now. i might relocate if inotice the car running hot in CA but i think so far no one has had a prob.
NorCALSpeed is offline   Reply With Quote
Old 02-04-2007, 05:00 PM   #153
Car: 07 STi Ltd UGM #504
best mod I've ever done. I ordered from Griot's and their wiring diagram and connections made it plug and play EXCEPT...
the wires were too short to connect to both horns (I kept them in the stock locations. Being off-centered sort of looks balanced to me from the front). So I had to buy an inexpensive bracket to get the center horn closer to the battery.
Worked great. Sounds great (maybe someday I'll post some of my FANTASTIC hella horn stories). Found that I actually use my horns LESS, b/c they're so right, I only use them for the morons they're intended for.
Griot's: True dat. Hella: Double true.
Scaed is offline   Reply With Quote
Old 02-16-2007, 11:19 AM   #154
Fav Mod: Rustoleum Flat Black
Finally had the time to get down into my horn problem last night and found it fairly quickly (10 minutes or so..). I ended up having a bad crimp connector at pin **. Replaced it, soldered everything and on came the train! Holy shiet...the little kids (about 3 or 4 yrs. old) down the street started crying when I tested it and scared the crap out of them...lol...they were okay when I let them come over and try it themselves..then they laughed uncontrollably. My neighborhood is fun.
These horns are gonna' be outstanding in commute traffic for those that didn't get the "turn signal option" on their stupid SUV's.
Thx. for the attempted help Lightwerkz.
grambo is offline   Reply With Quote
Old 02-16-2007, 02:27 PM   #155
Car: 08 Silverado 2500HD
what do i do with the two prongs on each horn.
1FSTSTI is offline   Reply With Quote
Old 02-16-2007, 02:30 PM   #156
See my response to your other post bro!
Old 02-16-2007, 03:30 PM   #157
How do I tap into the wire so it can go to both horns. Do I ground both horns?
Old 02-16-2007, 11:09 PM   #158
Welcome to The Board
Car: 06 WRB STI
Fav Mod: Advan RS
Send a message via ICQ to Ikon Send a message via AIM to Ikon Send a message via Yahoo to Ikon
Yes you ground both horn.. there are two pongs on each one. ground both horns then split two wires and on the open pongs plugs into the relay.. Read my DIY a few thraed down
Old 02-17-2007, 01:38 AM   #159
Car: 06 AW STI
if u have an 06 its a PITA to make the relay work.
Old 02-17-2007, 08:02 AM   #160
STI Master
Car: E46 M3
Fav Mod: ZCP Wheels
Trader Rating: (77)
^ Its the same as if your going an 05
Old 02-17-2007, 09:04 AM   #161
Car: 06 WRB STI
Fav Mod: Advan RS
no really just have to find the right ground. taht is what i had problem i had with. but other then taht only hard part is takign off the grill for both 04and 06cars
Old 05-31-2007, 08:42 AM   #162
Car: 06 OBP STi
Fav Mod: ??? dunno yet :)
Send a message via AIM to S D M F
Default Re: **DIY Hella Super Tones Install **
is there any reason you used 14 gauge wire???? I have 16 stranded in my posession, any reason why that wouldn't suffice??
S D M F is offline   Reply With Quote
Old 06-04-2007, 11:51 AM   #163
Car: 06 OBP STi
Cool Re: **DIY Hella Super Tones Install **
Okay i answered my own question in the previous post. With the help of Werkz' great write-up i installed mine today, there are a few things that are different on the 06 so here are some pics to show how i installed on my 06. There is only one wire going into the horn, thats your postive lead. I mounted mine right behind the center grill..
I used an environmental splice and heat shrink to add onto the stock horn wire...
Next i ran the +12V wire from the batter out the back of the cover down and thru...
I grounded both my horns behind the lower one...Make sure if you dont use the grounding point for the battery, you sand the place you use down to bare metal or you wont get a good connection to ground...
Here are a few pictures of how i ran my wire, lacing, and how i mounted my relay...
and now the final product!
These suckers are LOUD, too.
P.S. I would be willing to help, or install these for anyone in the pittsburgh, pa area.
Old 06-04-2007, 12:57 PM   #164
Car: 06 STI
Fav Mod: Your MOM!!
thanks for that 06 DIY, and is there anyway to get them next to each other so they arent off looking? thanks
Old 06-04-2007, 02:37 PM   #165
Car: 06 OBP STi
without drilling, i dont think so...
and thanks
