Old 01-23-2007, 02:12 PM   #136
Car: 06 AW STI
Fav Mod: Hardwired 8500
i cannot get these to work. i followed the writeup so i dont get it. ive tried the pos running to each horn terminal, checked my wire coupler and it was loose so i redid it, nothing. i tried running a single wire from the pos terminal on the relay to only one horn, no matter which prong, and nothing. i hear something click, i assume its the relay but no horn. could my grounds be bad because of the paint on them mount locations? is it different on an 06? theres white paint where i mounted the horns maybe thats preventing them from grounding???
NorCALSpeed is offline   Reply With Quote
Old 01-23-2007, 07:08 PM   #137
I'm Jim Halpert
Fav Mod: Ricer Flyby
just a question..... how is this DIY different than how a professional tuner shop would install them?
Old 01-24-2007, 11:20 AM   #138
Car: 2006 STi
Fav Mod: Any Turbo Upgrade :)
Send a message via AIM to STI.KID
^^^ it's not^^^ Other than the price
STI.KID is offline   Reply With Quote
Old 01-25-2007, 07:45 AM   #139
Fav Mod: Rustoleum Flat Black
I wanted to add an idea I had for the install. For those that use the included instructions and this great DIY....here is where I put the 20A fuse.
Not the best pic but, meh....whatever.
Another crappy pic of my S-Tones...
All my wires are double shrink-tubed and loomed for a factory look. It was a bit** to get into the fuse box but it came out really clean. (Note: I had to make sure that I had enough slack inside the fuse box so the cover was removable. The fuse holder is available at, pretty much, any electronics store.)
grambo is offline   Reply With Quote
Old 01-25-2007, 12:35 PM   #140
Car: 06 AW STI
did u have to do anything special to get the relay to work on ur 06? i tried following the DIY directions and they wouldnt work so i just did it with the stock wires.
Old 01-25-2007, 01:03 PM   #141
I'm Jim Halpert
has anyone who has an 06 have to remove some stuff to make them fit behind the little grills?
Old 01-25-2007, 02:28 PM   #142
Car: 06 AW STI
i didnt but that was mounting them more to the center on the white (or in ur case blue) radiator type cover. its close but they fit. if u mount them more to the outside, or on the radiator support, youll have to cut away the plastic that directs air fromt he outside of the grill toward the center.
Old 01-25-2007, 03:02 PM   #143
To be honest, I spent so mych time OCD'ing on the UBer trick Fuse placement and protecting the wiring that I have yet to finish. I need to add the last wire fo rthe horn circuit. I'll update.
It seems that most guys on this thread have used the relay though.
Old 01-25-2007, 08:36 PM   #144
Car: 06 AW STI
well this weekend my elec. engineer buddy is going to look at it for me and see what theproblem is. not sure if he acn help but it seem either the relay is bad or the numbers on relay arent what they should be. i dunno but for now i have a horn again, its pretty damn loud even without the relay but damnit i want those 118db
Old 01-25-2007, 09:12 PM   #145
Car: 06 WRB STi
I placed mine in the same spot as grambo's pics and didn't have to cut a thing.
webcrawlr is offline   Reply With Quote
Old 01-28-2007, 08:53 PM   #146
Car: '07 STi Limited
For those of you who installed these on the '06/'07s, did you use the stock bracket the Hellas came with? Also, did you have to drill holes in the rad support? I'll be installing Hellas on my '07 STi and just wanted a better idea about mounting them. Does anyone have any pictures of the Hellas mounted an an 06/07 with the grille off? Thanks.
Jay26 is offline   Reply With Quote
Old 01-28-2007, 09:08 PM   #147
Car: 06 AW STI
u can use the stock brackets but drilling a second hole will keep them straight should u have to mount them sideways. if u mount them on the radiator supports on the sides u might have to cut the plastic on the back of the grills for it to fit.
Old 01-29-2007, 09:52 AM   #148
Car: 07 WRX STi
can anyone link me to "I'm stupid and cant get my grill out/off" for an 06/07?
Ooie is offline   Reply With Quote
Old 01-30-2007, 11:21 AM   #149
Grab a good flashlight and look behind the grills...the center comes out easiest after the removal of the plastic-inserts in the top...the sides are a kinda' bitc*. You can reach around from behind after the center grill is removed and feel the push-in tabs and the shoulders you must push through the slots. Get the inside off first (closest to center grill) then the outside. Note: The colored part of the grill comes off with the black all in one piece...BE CAREFUL to not break the tabs...be patient..go slow...etc.
Enjoy your install.
Old 01-30-2007, 11:59 AM   #150
Car: 07 WRX STi
I found out the hard way
Plastic tabs+18degree weather=needs a new grill.
