Old 06-30-2008, 08:29 AM   #91
jtc
Default Re: DIY: How to bleed STI Brembo brakes
Beware that when you are using either the cheap suck or blow pressure systems you are putting pressurized air in direct contact with your brake fluid.
The air bubbles in a brake system are usually microscopic is size ie not visible to the naked eye.
There is a reason that professional pressurizing systems have a diapham between the air and the brake fluid.
Also from reading the booklet for my 06 STi the brake system seems to only have a total volume of 500 ml or so. For that reason I would see no reason to use 1 1/2 quarts of brake fluid.
Good link below. Lots of good tech info at Stoptech.
StopTech : Balanced Brake Upgrades
jtc is offline   Reply With Quote
Old 08-04-2008, 05:20 PM   #92
Fav Mod: CarComfortDesign@Gmail.com
what should you do if you accidentally run dry? for maybe one brake pump
JZeezSTi is offline   Reply With Quote
