Old 07-07-2007, 08:19 PM   #121
Car: 2oo5 cgm STi
Default Re: The Complete Radar Detector hardwire/V1 mounting guide
Originally Posted by SoaReS
Thanks for the quick response. Would you happen to know which wire is the ground?
I would have to assume black, I just grounded mine to the body using one of the screws that was up there.
Originally Posted by archimedes
Now does our built in sun dots by the mirror effect the detection at all?
Been discussed over and over, read the whole thread. no proof either way.
Old 07-07-2007, 08:29 PM   #122
Car: Swp 07 Sti
Fav Mod: Catless 3.5'' exhaust system
Send a message via AIM to archimedes
sorry budd, now here's a question that I may have to call Escort for, why does my radar go crazy and say laser when I accelerate hard? any ideas? mb a surge of electricity going into my 12v cig. lighter>? 07 Sti is what I drive if it helps any.
archimedes is offline   Reply With Quote
Old 07-07-2007, 09:31 PM   #123
Car: 2oo5 cgm STi
^^^ yeah, my old V1 would do that in my WRX, I called it my "turbo detector" - something about a dip in the power voltage, give Escort a call.
Old 07-08-2007, 06:43 AM   #124
Car: 05|WRB|STi
Fav Mod: Cobb Stage 2
Send a message via AIM to SoaReS
austinpike thanks for answering my questions Now i can get my v1 hardwired instead of using the cig lighter
SoaReS is offline   Reply With Quote
Old 07-09-2007, 01:05 PM   #125
Car: 05 WRB STi
Fav Mod: Pro Tune
I've been running this setup for over a year now and love it. I don't believe the dot's effect the radar at all. If anything, it detects better now that it is up there. The only thing that I know that will effect radar is if you have a heated windshield.
ilikepie is offline   Reply With Quote
Old 08-15-2007, 05:19 PM   #126
Fav Mod: Valentine 1
Send a message via AIM to boozy04
For any 07's out there. the Yellow with Red stripe is the power wire you want, and you can just use one of the screws you took out for a grounding point.
boozy04 is offline   Reply With Quote
Old 03-16-2008, 10:59 AM   #127
Car: 08 Gray STi
re: vampire taps.
avoid them. they clip some of the wires as they slice through the insulation. they introduce a potential failure point where vibration and moisture can enter.
my main recommendation is to solder, and seal with liquid electrical tape followed by shrink wrap.
if not that then PosiTaps are the best way to go. Instead of slicing through strands of wire like the vampire taps do, this pokes through and makes a weather resistant tap without the associated problems. Posi-Lock(TM) - The Best Connectors You'll Ever Use!
And, yes, the V1 is sensitive to voltage dips/spikes. Had it wired to my horn circuit on the bike. Every time I blipped the horn, the V1 would trigger. I moved the connection.
Old 03-16-2008, 11:13 PM   #128
Fav Mod: Cobb AP Stg1
Send a message via AIM to baneonrt
I just finished a hardwired V1 installation in my '08 STi. I figure it might be usefull to link to it here:
Steve's '08 WR Blue STi - Panavise Mount (5/9/08)
Steve
baneonrt is offline   Reply With Quote
Old 04-15-2008, 03:27 PM   #129
Great info on here for the hardwire. I have an escort and after several attempts to mount various places I finally mounted to headliner just to the left of the mirror mount. I just used the windshield mount with the suction cup's removed and a couple of small bolts and washers from Home Depot to bolt the mount to the headliner. very clean look and not that visible from outside. I tested behind the dots vs not in several places and couldn't find any difference. My main goal was maximum range to the front and maximum concealment from the sun and thieves. Working perfectly so far.
tjsadler is offline   Reply With Quote
Old 05-21-2008, 07:45 AM   #130
Car: 06 WRX STI
Fav Mod: Snow Meth Injection
Has anyone used the invisicord product? I used it on my Corvette and it says it is compatible with the 2004+ Impreza: Invisicord - Installation
No splicing involved. You just push the two pins in the positive and negative leads. Anyone tried it?
BicketyBam is offline   Reply With Quote
Old 05-21-2008, 10:12 AM   #131
Car: OBP 05' STI
Fav Mod: blacked out headlights ;)
thanks for the great write up i plan on doing this soooon!
blackxsti is offline   Reply With Quote
