Old 06-10-2007, 04:12 PM   #106
Fav Mod: I can only choose one?
Send a message via AIM to Stargazer
Default Re: The Complete Radar Detector hardwire/V1 mounting guide
Originally Posted by gondychi375
Would tinted windows effect the V1 (or any radar detecors) performance? Since it does block out UV light, I am thinking it might also block out other waves.
Only if the tint is metallic. Metallic tint will affect any radar detector to certain degree. How significant that effect is, is debatable.
Stargazer is offline   Reply With Quote
Old 06-10-2007, 04:35 PM   #107
Fears smelly diff fluid
Fav Mod: Invidia G200
Ok that's good to know. I just got my tints on this past Wednesday (5% in the backs and 35% on the front doors), and was worried about that. Just got done hardwiring my V1... I clocked myself at 11 minutes on the dot! I mounted mine just to the left of the rear view mirror... I have tried a few mounting positions, and when I drive by the speedtrap on I88 on my way to work everyday, it seems to pick it up sooner at this location!
Old 06-10-2007, 04:42 PM   #108
Car: 06 CGM STi
Fav Mod: brake dust generators
Send a message via AIM to osbjmg
Yea, I went with the ceramic tint so I would just make sure there is no interference.
osbjmg is offline   Reply With Quote
Old 07-06-2007, 07:26 AM   #109
Car: 05|WRB|STi
Fav Mod: Cobb Stage 2
Send a message via AIM to SoaReS
For those who dont have a powered rear view mirror, which wire did you tap for power?
SoaReS is offline   Reply With Quote
Old 07-06-2007, 09:01 AM   #110
Car: 2oo5 cgm STi
^^^ as I recall, the harness should be there anyway, even if you don't have the mirror, and you can get power from that...
Old 07-06-2007, 09:04 AM   #111
Car: 05|WRB|STi
Yes I do have 2 harnesses. One is for the lights, and the other is the harness I believe your talking about. I just dont know which wire is the power wire..
The harness I have doesn't have any blue or green wires. It has a black wire, a yellow wire with a strip of red, and a brown wire with a strip of white.
EDIT: I took the picture from the original poster, these are the two harnesses I have...
Old 07-06-2007, 09:55 AM   #112
Car: 06 CGM STi
I used the "add a fuse" thing . I didn't have to splice anything, just come right off of the fuse box then go up the A pillar.
Old 07-06-2007, 09:58 AM   #113
Car: 05|WRB|STi
Add a fuse? Care to elaborate?
Old 07-06-2007, 10:26 AM   #114
Car: 06 CGM STi
check this out (add a circuit):
http://www.partsexpress.com/pe/showd...number=071-580
Old 07-07-2007, 05:35 PM   #115
Car: 05|WRB|STi
BUMP! Can anyone answer my question in post #113
Old 07-07-2007, 06:59 PM   #116
Car: 2oo5 cgm STi
^ I looked at mine, the blue wire mates up to the yellow w/red stripe, so that would be the one.
Old 07-07-2007, 07:30 PM   #117
Car: 05|WRB|STi
Thanks for the quick response. Would you happen to know which wire is the ground?
Old 07-07-2007, 07:46 PM   #118
Car: Swp 07 Sti
Fav Mod: Catless 3.5'' exhaust system
Send a message via AIM to archimedes
Now does our built in sun dots by the mirror effect the detection at all? Like is the lenses able to beam through that to be accurate or does it throw it off a lil?
archimedes is offline   Reply With Quote
Old 07-07-2007, 08:19 PM   #119
Car: 2oo5 cgm STi
I would have to assume black, I just grounded mine to the body using one of the screws that was up there.
Been discussed over and over, read the whole thread. no proof either way.
Old 07-07-2007, 08:29 PM   #120
Car: Swp 07 Sti
sorry budd, now here's a question that I may have to call Escort for, why does my radar go crazy and say laser when I accelerate hard? any ideas? mb a surge of electricity going into my 12v cig. lighter>? 07 Sti is what I drive if it helps any.
