Old 04-23-2007, 05:52 PM   #91
Fav Mod: I can only choose one?
Send a message via AIM to Stargazer
Default Re: The Complete Radar Detector hardwire/V1 mounting guide
I remember seeing someone with another vehicle make who had hidden it in the 3rd brake light. Tinted windows would probably make it less visible without having to resort to a hat. Maybe a tissue box with holes cut into it?
Stargazer is offline   Reply With Quote
Old 04-23-2007, 08:43 PM   #92
Car: 06 Subaru WRX STI
Send a message via AIM to dukenukem
That would be the indian car camoflague
Very interesting idea right there ! thanks
dukenukem is offline   Reply With Quote
Old 04-23-2007, 09:10 PM   #93
Car: Black 07 STi
Originally Posted by The Brick
and that hat doesnt effect the V1 or the strength of the signal?
if you put a hat over antenna of a radio, would it effect the radio or the strenght of the signal?
X, K and Ka bands are radio frequencies.
Laser is a light(infrared), and it will be effected by the hat, but i've been shot with police laser a few times already and it catches it.
RADAR - RAdio Detection And Ranging
LASER - Light Amplification by Stimulated Emissions of Radiation
altezza is offline   Reply With Quote
Old 04-23-2007, 09:58 PM   #94
The weak ones, no? Wouldn't you want the V1 to catch the weak signals for maximum protection? Any detector can detect the strong signals.
Edit: For sure, the effect of the hat is small, but it's not 0%.
Old 04-23-2007, 10:47 PM   #95
Car: Black 07 STi
how is a hat going to effect radio frequency.
lets put it this way, put your cell phone on the table and see how many bars it has. now put a hat on top of it and see how many bars it has.
Old 04-23-2007, 11:14 PM   #96
Think of a radar unit as a flash light. Instead of emitting visible light, radar emits invisible electromagnetic waves at a certain frequency. When you shine a light beam from a flash light over an object, the light is reflected back to your eyes so that you can see the object. The same principle applies to radar beams. The electromagnetic wave that radar emits is called microwave, which will reflect off most metallic objects, concrete, trees, wood etc. It will however go through grass, bushes etc, just like light will go though glass and transparent objects.
Obliviously, the hat is porous and the V1 can detect strong radar signals even while covered, just like you'd probably be able to see light if you shined a flashlight on it. Those are strong signals. But what makes the V1 better than other detectors is its ability to detect weak signals. Weak signals can only deteriorate if there are additional obstacles. It might not be that much deterioration, but you can't say there is none.
To use your radio metaphor, I live at the top of a mountain and the radio reception at my house can be quite good/poor. I can get stations in Seattle quite clearly because they are broadcasting very strong signals. But our local stations, I don't get so well because the signal is less and it's blocked by a neighboring mountain. If I were to move my clock radio around or cover it up it would affect the clarity/quality of the weak stations, but not affect the quality of the strong stations.
Any radar detector can detect strong signals. People usually buy the V1 because it can detect the weak ones.
Check out this page from V1 about testing radar detectors and how radar works:
http://www.valentine1.com/lab/MikesLabRpt5.asp
And this one about how radar works:
http://www.magma.ca/~fyst/appndxc.htm
Old 04-23-2007, 11:43 PM   #97
Car: Black 07 STi
ok, i'll agree with you, the hat will have some small effect on the V1.
anyway, i've used it like that for years and it works good enough for me. the reason it's under the hat is because i would hate to find my car with a broken window one morning. maybe someone can come up with better idea, like you suggested a tissue box.
Old 04-24-2007, 07:59 AM   #98
Agreed! I still think your setup is one of the best I've seen.
Old 04-24-2007, 08:09 AM   #99
abracious
Fav Mod: Track time
time for someone to read up on electromagnetic energy.
Old 04-24-2007, 08:10 AM   #100
abracious
Fav Mod: Track time
the "light" spectrum
Old 04-24-2007, 08:47 AM   #101
Car: Black 07 STi
i did last night, after the coments from Stargazer
it's all waves, just different frequencies and wavelengths.
specs for V1:
10.500 - 10.550 GHz (X band)
24.050 - 24.250 GHz (K band)
33.400 - 36.000 GHz (Ka band)
820 - 950 nanometers (Laser)
Old 04-24-2007, 09:31 AM   #102
Car: 07 Sti
can anybody tell me if the 07 Sti with the standard mirrior has different wires to hook up the v1
new2subaru! is offline   Reply With Quote
Old 04-24-2007, 09:54 AM   #103
Car: 06 Subaru WRX STi
Fav Mod: stage 2
call me an idiot, but this is way to technical for me, hat covering the V1 will effect it, whether it be a big effect or a minuscule one, it still does effect it.... correct?
The Brick is offline   Reply With Quote
Old 04-24-2007, 11:26 AM   #104
Car: Black 07 STi
^ if you are traveling for somewhere where you need full protection, you can always take the hat off, just make sure to put it back on when you park, so bad eyes don't see it.
but honestly, i don't think you'll see any difference in the performance of the V1(accept Laser detection)
Old 06-10-2007, 03:16 PM   #105
Fears smelly diff fluid
Fav Mod: Invidia G200
Would tinted windows effect the V1 (or any radar detecors) performance? Since it does block out UV light, I am thinking it might also block out other waves.
