Go Back   IWSTI.com: Subaru WRX STI Forums > IWSTI Engine & Drivetrain > How-To / Install
Old 02-08-2010, 12:42 PM   #1
Car: Silver 2010 WRX STi
IWSTI Addict since: Feb 2010
Default How to do an oil change in STi 2010?
I'm new here and I have been looking around for "how to" do an oil change for a 2010 Sti. Please help, greatly appreciate.
foreverspeed1984 is online now   Reply With Quote
Old 02-08-2010, 12:54 PM   #2
Car: Blue 07 WRX STI
Fav Mod: Soap
IWSTI Addict since: Apr 2007
Default Re: How to do an oil change in STi 2010?
Welcome to the forums. Read the stickies in the FAQ/Newbie forum. The 2010 STI is not going to be much different (if at all) from the 2004-2009 STI's when it comes to changing the oil. There is already a How-To for this procedure. Check the How-To catalogue. It is stickied in this section of the forums.
Engine Oil Change 04 STi
You should purchase an OEM oil filter unless you research a better one. You'll need a sealing gasket washer for the drain plug. The dealer will normally ask if you want one when you purchase the filter.
Use 5W-30 oil unless your manual or oil cap specifies otherwise.
STI Sibb is offline   Reply With Quote
Old 02-08-2010, 01:26 PM   #3
Thank you so much for a fast response. I kind of know how to change the oil but since my STi has an under guard panel which is in the way, so I don't know if anybody has come up with any brilliant idea. Should I remove it permanently. It is very inconvenience to remove it every time I have to change oil. Thank you!
PS. This site kicks *** lol
Old 02-08-2010, 02:35 PM   #4
Car: Blue/Gold 08 Sti
IWSTI Addict since: Dec 2008
This will help if your having an issue with removal.
Remove the plastic engine bay gaurd & install a FilterMag on a 2008+ STI
I personally always leave the splash gaurd on my cars
skirkha3397 is offline   Reply With Quote
Old 02-08-2010, 04:48 PM   #5
Fav Mod: Frontal Lobotomy
IWSTI Addict since: Sep 2004
It's a pain in the a$$ to remove the splash guard each time, but your engine bay will be much cleaner if you go to the effort to put it back on after the change. I'm very tempted to cut a little door to access the oil filter without removing the tray.
Also, check out a Fumoto valve. Almost as ubiquitous on Subies as Supertones.
QuickOilDrainValve.com - the best way to change oil
gargleblaster is offline   Reply With Quote
Old 02-08-2010, 07:48 PM   #6
Fantastic, Thank you so much for those links. I just can't believe it, Why Subaru a multi billion automotive company can't design the guard in such a way that you can access to the oil filter much easier. Anyway, my car only has 380 miles now, the first 3,000 is free, so I will probably cut a hole on my guard and install the quick valve on the second oil change. Thanks a lot you guys.
Old 02-10-2010, 07:24 PM   #7
My wife's '05 Outback had a little trap door to access the oil filter. Why they did not incorporate that into this car is beyond me.
Similar Threads
The Oil Extreme Oil Change by Interior Flair! Interior Flair Engine/Power/Exhaust 30 07-29-2009 08:30 AM
Motor Oil - All Chapters, Inclusive -Hat Tip to Ferrarichat.com thrlskr 2.5 Liter/Litre Factory Motor 28 11-21-2008 10:53 AM
Why is the STI oil change recommand at 3,500 Miles Blip 2.5 Liter/Litre Factory Motor 49 07-12-2008 08:34 AM
1st oil change - The dealer didn't change oil & filter pantag General 57 02-24-2006 02:27 PM
Privacy Policy
