Go Back   IWSTI.com: Subaru WRX STI Forums > IWSTI Engine & Drivetrain > How-To / Install
Old 12-30-2009, 03:13 PM   #1
Car: Blue 08 STi
Fav Mod: Stage 3
IWSTI Addict since: Sep 2009
Default Change 2008 Transmission Oil
Give props to this thread
2008 STi transmission oil change
and this thread
Changing 6MT trans oil
Tools Needed:
1. 75w 90 Extra S Subaru gear oil.
4.1 L (some use motul, it depends on your taste)
2. Long funnel
3. Torx 60
4. 10 MM allen and 1/2 torq bar
Steps:
1. Jack the car
2. Pop the hood and locate the screws
use 10 mm allen to take out the screws (remember lefty loosey), you may need a breaker.
3. Locate the screws below:
you need torx 60 for this screw
you need 10mm allen for this screw
outcome: oil is not that dirty... you dont really need to change it. according to the subaru booklet. it only needs I = inspection. I dont get how they expect us to inspect it without draining the oil?
lots of metal shavings
it took 3 tissues to clean it
4. After you drain it, put back the 2 screws you took out from Step 3.
5. Fill Step 2 with 75w 90 oil = 4.1 L
Aftermath:
yup its dirty:
oil that came out:
bunta is offline   Reply With Quote
Old 12-30-2009, 03:17 PM   #2
Feedback Score: 1 reviews
Car: DGM 09 WRX STI
Default Re: Change 2008 Transmission Oil
Thanks. Going to be doing this at my 15k mark. How full do you fill it? Exactly 4.1L? To a fill line? Until it overflows? Etc?
Sabrewings is offline   Reply With Quote
Old 12-30-2009, 03:20 PM   #3
Car: Blue 08 STi
Fav Mod: Stage 3
I filled in the used empty 5 liter engine oil with the 75w 90. You can see it has a measurement on that side to make sure it has 4 to 5 liter.
I heard some people fill it till it overflows but i dont want to waste the oil.
Old 12-30-2009, 03:21 PM   #4
Car: DGM 09 WRX STI
Isn't there a trans dip stick? May go that route.
Old 12-30-2009, 03:36 PM   #5
Car: Blue 08 STi
Fav Mod: Stage 3
that was 2007, the 2008 doesnt have a tranny dipstick. (thats what ive seen from another thread.)
Old 12-30-2009, 04:28 PM   #6
Car: WRB 08 STi
IWSTI Addict since: Nov 2008
I thought the filler hole on the 08 was on the drivers side of the car, on the side of the transmission.
KingPest is online now   Reply With Quote
Old 12-30-2009, 04:58 PM   #7
Car: 08 silver sti
IWSTI Addict since: Dec 2008
its on the side fill until fliud comes out op might have over filled it if he went from top plug
olderthanold is offline   Reply With Quote
Old 12-30-2009, 05:11 PM   #8
Car: DGM 09 WRX STI
According to the factory service manual, the fill plug is indeed on the side:
Old 12-30-2009, 05:15 PM   #9
Car: WRB 08 STi
IWSTI Addict since: Jan 2009
its on the side but as long as the top hole goes into the same place does it really matter? if you measure how much you took out and put same back in, i dont think overfilling would be much of a concern,
severe is offline   Reply With Quote
Old 12-31-2009, 09:58 AM   #10
Car: Blue 08 STi
Fav Mod: Stage 3
at section A., "oil level is up to the bottom of the filler plug." How can you check that? I cant see any oil from the side of the car and stuff from the engine is blocking the front view. You cant see the oil level at all.
Similar Threads
How-To: 2008 rear diff oil change nysulli How-To / Install 0 11-07-2009 10:39 AM
Zen Motors -2008 STi Goodness! Engine Builds, Fmic, Exhaust, Turbo Kits,Suspension, ZenMotors GR-Vendor Announcements 22 04-01-2009 07:27 AM
The Oil Thread. ACHAHockey 2.5 Liter/Litre Factory Motor 2 01-29-2009 11:37 AM
1/7/2008 Dealer Inventory! (153 in stock) chippyhawkeye GR-General 32 01-24-2008 10:40 AM
Synthetic oil change and gauge question JonnyAvacado 2.5 Liter/Litre Factory Motor 5 01-11-2006 12:47 PM
Privacy Policy
