Old 10-05-2006, 07:15 AM   #91
Car: 06 Aspen White STi /
Send a message via AIM to scottjua Send a message via Yahoo to scottjua
bump for updates?
scottjua is offline   Reply With Quote
Old 04-07-2007, 07:29 AM   #92
Car: 05 STi CGM
Hmmm...I am deffiniatly going to do this mod, but I am thinking about adding a cap and a few other things in there so as to make the LEDs flash at about 10kHz (faster than the eye can see) which will make them a LOT brighter. I'll sketch up a quick circuit and try it out...may not be worth it.
decodeddiesel is offline   Reply With Quote
Old 04-09-2007, 12:42 AM   #93
Car: 05 Subaru WRX STi
Hmm. Wouldn't changing the duty cycle of the LED's make them dimmer? I guess it depends on how they're setup stock.
Darksabre is offline   Reply With Quote
Old 04-09-2007, 06:55 PM   #94
Car: 05 STi CGM
Yes it would make them dimmer if you kept the same current to the LEDs, however the beautiful part about flashing them (at a couple 100 Hz) is you can up the current and make them brighter. It's not hard using an LM555. Problem is an LM555 has a max current of 200 mA, so 200/6 = 33 which isn't that much more then the 20mA the LEDs I am using normally draws. I'll have to think about this more and figure something out.
Old 11-29-2007, 11:13 AM   #95
Reasonable
Fav Mod: correct grammar
Default Re: HOWTO: 2005 STI HVAC Red Light Mod
Hmmm. I want mine to be blue. I wonder if I could just color the stock LED yellow. Then when it went through the green plastic, would it then be blue...
