| | #71 |
| S204 Racer Feedback Score: 12 reviews | Karl, I'm going to do the DIY install based on the link you sent using the Husky blow-by can probably around the first of March. I'll make sure to take lots of pics. Funny thing is the owner of the link is a guy I used to AutoX with in Tucson, so small world. |
| | #72 | |
| Amateur STI Driver Feedback Score: 0 reviews Car: 04 Subaru WRX STi Fav Mod: Passport SRX Location: Jacksonville, FL Posts: 11
IWSTI Addict since: Oct 2005 | Quote:
| | #73 |
| Senior STI Driver Feedback Score: 3 reviews | I'm curious if you could emulate crawford's return with your setup. The way I see it, and i really do like your setup, you will most likely be under boost should you hit redline, and you will most likely be under boost should you have excessive crankcase pressures, and that's when you lose oil, the breathers would be doing all the work, and it's through the breather can that you will get most of your oil. So looking at how Crawford has his catch can setup, he has a return hooked up back to one side of the breather, going into the valve cover, I'm assuming putting the TEE as low as possible for drainage, which would drain when the car is off. What are your thoughts of plumbing it this way? |
| | #74 |
| NIИja Feedback Score: 5 reviews My Stuff: Subaru Parts Location: US - Southern California Posts: 38,347
IWSTI Addict since: Jan 2006 | I purchased a Perrin unit, with what I guess is the new one with only 1 input. You guys mentioned before that the perrin allowed for a breather and pcv input (maybe only with a "t" that is not supplied in the kit). Anyways, after reading Wolfs great write up I am not sure which should be of priority with my one can. I am tuned to ~19lbs, and I am now seriously considering installing this. I have had it for a few months not thinking I would need it til now. 91octane is bad enough, I don't need oil making it worse. In your experience with your cars which should I plumb? What pukes the most oil? Perrin instructions say PCV. PCV? Breather? Thanks. |
| | #75 |
IWSTI Addict since: Jan 2006 | Pcv or breather? |
| | #76 | |
| | #77 |
| Professional STI Driver Feedback Score: 0 reviews
Car: White 06 STi Fav Mod: Tein Hood Dampeners Location: Dallas Posts: 416
IWSTI Addict since: Feb 2006 | I Didnt Know Where They Were In The Engine Bay Until I Saw A Close Uppic! I Love It It Looks Stock!! Great Product Im Buying One For Sure! |
| | #78 |
| S204 Racer Feedback Score: 8 reviews
Car: 06' CGM STI Fav Mod: Rustoleum Flat Black Location: Tracy, NorCal Posts: 3,207
IWSTI Addict since: Oct 2006 | You inspired me, so I thought you'd like to see another take on the AMW catch can installation: I triangulated teh aluminum for strength and used the two factory holes in the same location as you did. You can see here where I had to bore a larger hole in the front of the bracket to get the SS hardware through to secure the piece via the samller hole on the backside. My only problem is I don't like this part much. The bracket overlaps the mounting access hole. Oh well. I'll be polishing out the bracket to a mirror shine to match my power steering pump and header tank. Thanks for a great write up Wolfplayer. |
| | #79 | |
| Amateur STI Driver Feedback Score: 0 reviews Posts: 18
IWSTI Addict since: Mar 2007 | Quote:
Until I order another CC. Thanks! | |
| | #80 |
| Junior STI Driver Feedback Score: 0 reviews Car: 06 Subaru WRX STi Fav Mod: leaving it stock Location: H@w@ii Posts: 166
IWSTI Addict since: Apr 2007 | thought this kit would go great with your catch can.... has all the plumbing done for you....this is just the plumbing for sale i believe by the way...those catch cans look solid! too bad they raised the price so much! guess they were getting many orders for them. Dual Catch can plumbing kit Last edited by houdni; 04-06-2007 at 09:35 PM.. |
| Thread Tools | |
