| | #151 | |
| Junior STI Driver Feedback Score: 0 reviews Car: '05 WRX Fav Mod: Pro-Tune Location: Denver, CO Posts: 146
IWSTI Addict since: Feb 2009 | Quote:
1 for the two rocker cover vents before they go back into the inlet hose. 1 for the PCV vent to the turbo inlet hose. 1 for the PCV vent to the intake manifold. For some reason, I am not catching a dang thing in my PCV vent to inlet hose catch can whatsoever. I catch a little in the rocker cover breather can, but I catch the most in the PCV vent to intake manifold. So much that I have to empty it pretty frequently in fact. I just changed my oil today and got to wondering about it all. I am considering deleting my PCV vent to the intake manifold if it's not catching anything. Now, hopefully I won't get any crap for this but 2 of my catch cans are Home Depot air compressor filter style setups. The one on the intake manifold is a Husky and the one on the PCV valve is a Kobalt. I've checked them for leaks and made sure they're fine. They handle the heat and torture of an engine bay just fine. Going on 6000 miles so far with them. The one can off the breather vents is a Greddy ebay knock off though. It sucks. So in conclusion I'm really guessing that the only catch can that's worth a darn is the one off the PCV/intake manifold setup. Why could/would this be? Possibly because I have an aftermarket turbo inlet hose and had to put a resistor in the factory connection there at the PCV vent to the hose? Maybe the ECU doesn't think it's attached? Weird. | |
| | #152 | |
| Spec C Club Feedback Score: 4 reviews Car: 06 STI Fav Mod: stock Location: Phoenix Posts: 1,525
IWSTI Addict since: May 2006 | ^^Great idea, I think you're the first to do this. I've had the idea of running a 3 cc setup in the same manor for a while, but I'm still undecided on what I want to do. Out of the following text that you posted I don't understand the line in bold, it doesn't fit with the rest: Quote:
It's not surprising that the intake manifold pcv line gets the most oil. During off boost conditions - when the engine is in vacuum - the pcv valve opens and the oil has almost a straight shot from the crankcase into the intake manifold, completely bypassing the intake track. There's only 4-5 inches of hose between the crankcase fitting and intake manifold, it starts at 3/4" ID and necks down to around 1/4" ID about half way through. Considering this, it's ironic that nobody ever puts a cc on the intake manifold line, they always put it on the pcv turbo inlet line and/or valve cover breather lines. | |
| | #153 | |
| The Next Petter Solberg Feedback Score: 5 reviews | Quote:
| | #154 |
| STI Driver Feedback Score: 2 reviews
Car: WRB 04 STi Fav Mod: Stage 4 Halogen Fluid!!! Very rare :p Location: Rochester NY Posts: 205
IWSTI Addict since: Jul 2009 | subscribed for later |
| | #155 | ||
Anyways, yea, I'm sorry for the typo there. What I meant was I was considering deleting the PCV vent to the turbo inlet hose as it is not catching anything You're right about the intake manifold getting a straight shot of a few inches away from the PCV valve there, that's why I just figured I would see what it would do to put a catch can there. It seems to have made the biggest difference of them all. It catches the most oil (obviously the other two catch virtually nothing) and I'm sure that the black oil I see in the can can't possibly be good to be in the intake manifold. Correct me if I'm wrong. Quote:
I don't know why this is, but there are no leaks (tested twice with air and smoke). The only reason I can conclude is that possibly since I put a resistor in the plastic nipple thing that used to be on the stock inlet tube (I have a Gimmick one now) that the ECU isn't thinking it's connected properly? Er, I may be way off and sounding stupid, so I'll stop there. | ||
| | #156 |
| Junior STI Driver Feedback Score: 0 reviews Car: 06 wrx Fav Mod: stage 2! Posts: 140
IWSTI Addict since: Apr 2007 | what do you guys think of this? beatrush Gd Catch Tank ; Not Just Any Oil Catch Tank - NASIOC im not sure how i feel about it dumping back into the oil pan, im thinking i would rather just get a catch can. |
| | #157 |
IWSTI Addict since: May 2006 | ^^It looks pretty cool. They only thing is it only takes care of the valve cover breathers and not the crankcase vent. It looks like it does basically the same thing as the prova unit for less money. Even still, there's no reason that thing should be above $150 imo. |
| | #158 |
| STI Guru Feedback Score: 18 reviews
Car: '07 CMG STI Fav Mod: Not knowing how to "spell" hah Location: los angeles Posts: 5,333
IWSTI Addict since: Aug 2006 | ^ +1 I'm seing the most blow by out of the crankcase. |
| | #159 |
IWSTI Addict since: Apr 2007 | thanks guys! great info! so i should really look into a crank case catch can? |
| | #160 | |
| Amateur STI Driver Feedback Score: 0 reviews Car: Aspen White 04 STi Fav Mod: custom headlights Posts: 46
IWSTI Addict since: Jan 2009 | digging this up but this is for 05wrx Quote:
| Thread Tools | |
