| | #101 |
| Junior STI Driver Feedback Score: 0 reviews | wow im gona have to get a set of those when its released |
| | #102 | |
| Spec C Club Feedback Score: 3 reviews
Car: 04 STI Java black w/ Fav Mod: a garage Location: Just outside Manassass VA Posts: 1,803
IWSTI Addict since: Sep 2005 | Quote:
The kit was minimal and didn't come with anything other than the bracket and the cans. I used some 1/2" heater hose, hose clamps, and two 1/2" hose couplers. I'll post up pictures of the install later so it's clearer as to what I did. BTW I'm sure you could order the cans if you emailed Mr. Saikou. | |
| | #103 |
IWSTI Addict since: Sep 2005 | Ok, picture time: PCV nipple is the nipple all the way to the right. The short hose is the oem hose. It's 3/4" at the pcv nipple and 1/2" at the other end. Breather-into-inlet nipple is 3/4" and uses the oem hose. Some notes: The washers are huge, I know, I used them because they were in my garage at the time. I'm not entirely pleased with the hose that goes over that cap thing (coolant reservoir??). It doesn't interfere with the hood at all though and doesn't get pinched. Inlets are the top nipples on the cans outlets are the bottom. The car is dirty from salt on the roads and needs a full detail. |
| | #104 |
IWSTI Addict since: Sep 2005 | I've encouraged the maker to speak with Kevin about doing a group buy. |
| | #105 |
| Spec C Club Feedback Score: 4 reviews Car: 06 STI Fav Mod: stock Location: Phoenix Posts: 1,520
IWSTI Addict since: May 2006 | Thanks for the pics. It's hard to tell but, it looks like you aren't using the pcv valve. If this is the case what did you use to cap the pcv port on the intake manifold? I was also suprised to see that the port coming off the top of the can is the inlet and the lower port on the side of the can is the outlet; I figured it would be the opposit (not that it matters). |
| | #106 | |
The inlet and outlet port's were as labeled in the instructions. | |
| | #107 |
IWSTI Addict since: Sep 2005 | couple more pictures: |
| | #108 |
| Moderator & ECU Tech Feedback Score: 6 reviews
Car: 05 CGM STI My Stuff: Subaru Parts Fav Mod: mo boostaz Location: Fredneck, MD Posts: 4,110
IWSTI Addict since: Jun 2004 | Hi Guys, These catch cans look pretty nice for the money. I read through their website and it says that he uses the mesh for condensation and I think that is a great idea (so long as it is stainless steel). What I don't like about these cans is the simple fact that you cannot open them up to inspect what is going on. I have the need to see the internal workings of something and to examine it from time to time. Even with my AMW cans, I don't drain them without first cracking open the top and taking a look at things. Again - these seem great for the money. I just don't like the fact that you can't open them up and inspect. t |
| | #109 | |
My number one suggestion was making them something you could open up and peek inside. | |
| | #110 |
| The Next Petter Solberg Feedback Score: 3 reviews Car: 07 OBP/Gold STi Fav Mod: DomTune & MD Whisper Location: NW, Washington Posts: 915
IWSTI Addict since: Jun 2007 | ^^^ I have the same ones in my garage waiting to install. I bought the two piece set though, so my cans aren't welded together. |
| Thread Tools | |
