Subaru Impreza WRX STI Forums: IWSTI.com
Home  |  Register  |  Today's Posts  |  Go Premium  |  New Posts  | Mark Forums Read Create a Member Journal  |  Marketplace
Go Back   Subaru Impreza WRX STI Forums: IWSTI.com > IWSTI Engine & Drivetrain > How-To / Install
Old 04-19-2009, 11:15 AM   #21
STi_FTW's Avatar
Default Re: Repack Impreza Struts
Originally Posted by orbix View Post
I'm trying to do this at the moment, however I have hit a problem.
When i try and remove the nut from the underside of the strut housing it just keeps turning around even when I hold the strut assembly to stop that turning around.
Any ideas?
I have only tried it on one strut so far, later today i will try it on another strut and see if i get the same problem.
I had the same problem. After 3 hours I used an impact gun, I'd only recommend it as an absolute last resort though.
My Mods
COBB AP v1/Stage 2 - Prodrive Oil Cap - Intake Silencer Delete - Stock HIDs adjusted - Partial Debadge - Invidia Catless Bellmouth DP (wrapped) - Fortune Auto 500 Coilovers - Kenwood MP238 CD Player - Kenwood KAC 7203 1000w Amp - 2x Infinitey Reference 1020w Subs - SR*S Catback - Hawk HPS+ Front Pads - Gates Racing Timing, AC, Alt belts - Many more to come
STi_FTW is offline   Reply With Quote
Old 04-19-2009, 09:38 PM   #22
Feedback Score: 3 reviews
RAPTR's Avatar
Send a message via MSN to RAPTR
I will be doing this in the near future. Thanks for the great pics and instructions.
RAPTR is offline   Reply With Quote
Old 04-20-2009, 07:39 AM   #23
The Milkman
Feedback Score: 36 reviews
snorky's Avatar
Any ideas?
Sounds like the slotted part of the rod is out of the notch. Try compressing the strut while reversing the nut. It should slide back into the notch and allow you to remove the nut.
If not, the threads may be stripped.
Timmy
The Red Rocket. 30+MPG FTW
Old 04-20-2009, 12:28 PM   #24
Default Re: Repack Impreza Struts - failed
I gave up in the end.
I tried everything i could to remove the nut but no good.
I'll just have to put upp with the noise a little longer.
orbix is offline   Reply With Quote
Old 04-20-2009, 12:45 PM   #25
The Milkman
snorky's Avatar
sounds like the nut came loose and the threads are stripped.
Timmy
Old 04-21-2009, 11:44 AM   #26
still going strong? klunk is driving me crazy.. might have to do this if it lasts a while
chitownrida is offline   Reply With Quote
Old 06-15-2009, 05:07 AM   #27
Bump:
I did this on Saturday on my 05. My strut clunk is gone now.
It would have been a 1-1/2 hour job if it weren't for the rear drivers side rod nut!
Here's a tip: if the rod nut spins, the only way to get it off that does not involve cutting is to find a really strong impact wrench and give it the 'on-off-on-off technique' - meaning you hit the nut with the impact, let it stop spinning, and then hit it again. That way the hammers inside the wrench are actually 'smacking' the nut off. Compressing the strut itself is a good idea too to get some friction of the bumpstop, and the lower strut mount.
Once you get it off, and you're done with the job you're obviously going to want to get the nut back on.. I was able to get it back on by lubing up the threads with some Moly, and zipping it on as quick as I could with the impact wrench.
The passengers side was no problem at all... that darn drivers side took 2-3 hours.
All in all I'm glad I did it, because my grease reservoirs were pretty dry.
If you DON'T have air tools, and the lower rod nut spins put the struts back on the car, and find someone who has air tools. If you're stuck with the nut halfway loosened your suspension will be FUBAR'D, and will rattle like crazy.
-Des!
Mixelplix is offline   Reply With Quote
Old 06-21-2009, 05:54 PM   #28
The Stig
Feedback Score: 1 reviews
ytsohptwhere's Avatar
Snorky how is this holding up?
Old 06-21-2009, 06:31 PM   #29
bap2086's Avatar
coilovers
bap2086 is offline   Reply With Quote
Old 06-21-2009, 06:41 PM   #30
The Milkman
snorky's Avatar
Originally Posted by bap2086 View Post
coilovers
My struts have about 12k+ miles on them repacked. I pulled them apart a couple weeks ago for grins and giggles. Still full of grease. I'll take pics some time this week. I am on coilovers now so a long term test isn't really possible.
Timmy
Similar Threads
GENUINE Italian leather interior products for your Impreza STI! RedlineGoods Dressup/Interior 88 07-09-2010 11:12 AM
Jeremy Clarkson reviews the Subaru Impreza WRX STi eurospek GR-General 90 09-28-2008 08:50 PM
07 struts fit on 04 “well“ layza4sti GD-Suspension, Handling, & Stiffening 4 05-08-2008 03:29 PM
08 Impreza pricing: La Mer GR-General 4 07-18-2007 05:17 PM
WTT: 2007 Impreza Tail Lights for 2004-2005 Impreza Tails PERFECT CONDITION (norcal) wrxtunerd Private Wanted Classifieds 4 05-27-2007 08:15 PM
Powered by vBulletin® Version 3.8.6
Privacy Policy
