Old 07-22-2008, 10:43 AM   #1
Car: 04 STI
Default o2 SENSOR HELP
I drive an 04 STI, i need to replace an o2 sensor. Im not sure which one went bad, but if i ordered a replacement from Subyparts.com does anyone have a procedure to fixing the problem... thnx fellas
PrimeSTI is offline   Reply With Quote
Old 07-22-2008, 11:21 AM   #2
Car: 04 STI
Default Re: o2 SENSOR HELP
no responses...? HELP
Old 07-22-2008, 07:53 PM   #3
you have a bad o2 sensor on an 04 STI? that's weird..
so... u don't know which one doesn't work... that means, you don't really know which one you ordered... how can anyone help you??
I guess what you have to do right now is to find out which one doesn't work and which one you bought.. and from there, it's just locating the o2, unplug the old o2 and thread it back in...
are u sure it's the o2... usually o2sensor are designed to last 160000km
silhouette0922 is offline   Reply With Quote
Old 07-23-2008, 05:47 AM   #4
Car: Pearl White 07 STi
Well if you don't know which one is bad how did you buy a replacement? Theres 2 different ones on our cars and can't be interchanged. Well, good luck..
ryanwrxduksa is online now   Reply With Quote
Old 07-23-2008, 05:54 AM   #5
HowTo Contributor
Car: 2008 DGM (BBS+Navi)
Fav Mod: stock FTL?
How do you know one is bad? What is the CEL code that pops up?
P0420 is the rear O2.
P1153/P1153/P0139(?) and a few others are the front O2.
There are probably a few other CEL codes for both sensors.
You need to figure out which sensor is bad. Both are fairly easy to replace, unplug the connection and use an O2 sensor socket to remove. The front O2 in the exhaust manifold is a bit more of a PITA to reach but it's still not that bad.
Old 07-23-2008, 05:54 AM   #6
Car: Blue 07 WRX STI
Fav Mod: Soap
What problem are you having and how did you determine that you had a bad O2 sensor?
STI Sibb is offline   Reply With Quote
Old 07-23-2008, 11:19 AM   #7
Car: 04 STI
sorry to confuse ya fellas, i did not buy a replacement...yet, im just trying to get an idea how to solve the problem at my easiest convenience. I dont have a reliable shop to go to in my area, so im lookin into fixing it myself, however yes i dont know which o2 sensor is bad, nor do i know the locations. thanx for the responses, keep them commin....
Old 07-23-2008, 07:10 PM   #8
HowTo Contributor
Fav Mod: stock FTL?
HOW DO YOU KNOW ONE IS BAD?
Are you getting a CEL? If so post the code you are getting. Search on here/NASIOC/google for more info.
Advance Auto/AutoZone/etc all have CEL code readers that you can borrow to get the code. Take a minute and they can help you if you need it.
Old 07-23-2008, 10:14 PM   #9
yup.. get a code read.. then search it up.. and you'll know
