Go Back   IWSTI.com: Subaru WRX STI Forums > IWSTI Engine & Drivetrain > How-To / Install
Old 11-26-2009, 11:39 AM   #51
Car: WRB 2003 WRX
IWSTI Addict since: Aug 2008
Default Re: Clutch delay valve repost (with pics)
Originally Posted by kh15 View Post
i really want to do this mod to my 06 wrx but my slave cylinder looks completely different from past years. Since i had some spare parts laying around i decided to take them apart to see what i was working with...
the only thing i dont understand is why do i need to plug that little hole in the metal screw cap the screws on to the bottom of the master cylinder? does that little hole really do something?
other than that, why cant i just take out the little spring and blue cap and call it a day?
06-07 WRX have a "Push" type clutch, where 02-05 WRXs and 04-07
STI have "Pull" type.
The 06-07 STI has a different design slave cylinder (then the 04-05)
Pull Style- The release bearing is snapped into the pressure plate. It requires the release fork pivot rod to be removed to separate the transmission from the engine. The slave cylinder actuates forward (pointed away from the firewall).
Push Style- The release bearing and fork stay with the transmission when separating it from the engine. The slave cylinder actuates rearward (pointed to the firewall).
23-10 is offline   Reply With Quote
Old 01-05-2010, 07:54 AM   #52
949
Feedback Score: 3 reviews
Fav Mod: battery with new upgraded positve and neg terminals
IWSTI Addict since: Aug 2005
Send a message via AIM to 949
i did the mod and when i drive on the freeway i cant down shift without grinding 5th gear from 6th gear.
anyone also have this problem.
i have exedy stage 2 clutch.
i have no idea what else to do.
949 is offline   Reply With Quote
Old 01-05-2010, 08:32 AM   #53
Car: WRB 2003 WRX
I'm not 100% sure but I would check the fluid level, re-bleed it, check the slave and the shift linkage.
Also it could be your brass synchros, try changing the tranny fluid and use the OEM stuff.
Old 01-05-2010, 09:23 AM   #54
949
i have bleed the master clutch cylinder many times.
i dont think there are any air left but there could still be air somewhere in there.
can you explain more about the brass synchros?
i feel like the clutch isnt able to push the clutch apart on high speeds, i guess there is alot more pressure on those speeds. another time hit will do it is when i do a quick shift on any speed, slow speeds too.
i wonder if i should have kept the farrel in the slave cylinder?
this part of it.
Old 01-05-2010, 09:43 AM   #55
Car: CGM 05
Fav Mod: IAG 38mm EWG
IWSTI Addict since: Mar 2008
Send a message via AIM to 1loudsti
i took mine out and had no issues FWIW
1loudsti is offline   Reply With Quote
Old 01-05-2010, 09:59 AM   #56
Car: WRB 2003 WRX
Do a search on the synchros a lot of people have 5th gear grinding in 04-05s.
I dont think its a good idea to do a quick shift at high speeds & its not going to really slow you down if you do a normal shift. I think the ferrel is the main part of the delay delete.
Old 01-05-2010, 09:59 AM   #57
949
what was your procedure for bleeding it?
Old 01-05-2010, 10:04 AM   #58
949
i kinda feel its not the synchros cause this never happended until i did this mod.
Old 01-25-2010, 02:00 PM   #59
IWSTI Addict since: Nov 2009
I just purchased 8 of the bolts through Fastenal today. They'll be to me on Friday. I will be doing this modification.
My main reason for doing this mod is that I cannot get on the power as quickly when shifting from 1st to 2nd. There is a noticeable lag between the two gears that almost feels like the clutch is slipping(which it basically is). The delay valve is installed to ensure that any retard with no clutch experience can drive the car and not start snapping driveshafts and ruining the transmission.
I for one will do the mod and see how it feels. My M3 didn't have the delay valve installed and shifting on the power from 1st to second was quite enjoyable. If I don't like the feel after the mod, I'll just put it back to stock.
Are there any long term testers that have any feedback?
DougNM3 is offline   Reply With Quote
Old 01-25-2010, 03:45 PM   #60
949
i finally got the bolt in and bleed it. it works pretty good but im not sure if my bleeding steps are the correct way. i did notice after a week or so that the pedal does slowly lower. it doesnt come back completely all the way up. so it may come back up about 95%
im wondering if there is still air in it.
Privacy Policy
