Go Back   IWSTI.com: Subaru WRX STI Forums > IWSTI Engine & Drivetrain > How-To / Install
Old 08-19-2004, 08:18 AM   #11
Car: 08 Dark Grey STi
IWSTI Addict since: Feb 2004
Originally Posted by Scuba_Steve
Hmmm? I can burn all 4 at will, cut 1.6 60fts or drive it like a grandma and the clutch feels fine. So what is the benefit of this mod?
How are you folks spinning tires? Are you using tires other than the stockers?
I was never able to spin with stock tires, except once with the diff open at the track with a hard launch. And now, with AVS Sports (18", can't be any stickier than stock), I'm even less able to spin.
I'd be interested in doing this mod (hate the feel and jerkiness of the stock clutch), but I also don't want to snap any axles. As it is, I can drop the clutch at 6 grand and launch like crazy (1.67 60's). But I still never get any wheelspin...
serendipity is offline   Reply With Quote
Old 08-19-2004, 01:23 PM   #12
Car: 98 Impreza 2.0RS
IWSTI Addict since: Jan 2004
very informative write-up - thanks :wink:
Have you added any power mods to your car - this helps a great deal when trying to spin all four...
capaSTi is offline   Reply With Quote
Old 08-20-2004, 07:00 AM   #13
Default insane whp from stock internals
Yes - turboXS intake, TBE, and UTEC with about 21psi in the midrange. The car doesn't lack for power, I just don't understand these folks who say they burn all 4 at will. I launch the **** out of the car, and it just hooks and goes. I'd RATHER know that if I launch too hard, I'll spin instead of snapping.
Old 08-20-2004, 07:02 AM   #14
Feedback Score: 3 reviews
Fav Mod: GT-35R
IWSTI Addict since: Jan 2003
can you burn them on the street? i have seen scuba burn all 4 at a strip however, so it can be done.
cnstman is offline   Reply With Quote
Old 08-20-2004, 07:39 AM   #15
I haven't yet - I don't launch as often on the street as at the track, but the times I have, I still just hooked and went.
I was able to spin the back just a bit a few times by opening the diff and launching (at the track), but it was just the rears, and only for a second.
I don't doubt that it's possible. I'm wondering why. I suspect they are using less sticky tires or something.
Old 08-20-2004, 11:10 AM   #16
Fav Mod: GT-35R
he had the stock tires on when he did it, although they are quite worn. you should just try it on the street once, it is a rush!
Old 08-20-2004, 11:13 AM   #17
Fav Mod: GT-35R
click on the "108mph" in scuba's sig, that is the vid. he does a launch/burnout before the actual run. that was with all 4 spinning. i was behind him in the lanes for that run.
Old 08-23-2004, 07:32 AM   #18
IWSTI Addict since: Sep 2003
Scuba also has a different turbo on his car. He is making alot more power then stock which probably is why he can spin all 4.
STi_This is offline   Reply With Quote
Old 08-23-2004, 10:28 AM   #19
IWSTI Addict since: Mar 2004
Just a note to those who are going to do my mod posted here. The bolt can be hard to find as a few of you have mailed me with your troubles. The bolt can be found at most oil change places (rapid oil and such)
It is a Nissan or Volvo drain plug size m16x1.5x10mm This is a perfect fit and will not require the additional copper washers I pictured in the write up. You will just need to use the OEM washer in 5th picture and skip the copper washers.
For those who cant find the proper bolt you can mail me at
moshaff at qwest dot com and I can get one for you.
Matt
bikerboy is offline   Reply With Quote
Old 08-31-2004, 08:08 AM   #20
Car: WRB STi - WRR 92X
I just did this mod last night.
Thanks to Bikerboy who provided me the bolts...
(Probs to him who writes up this DIY)
The installation:
Pretty straight forward...
But you need to go underneath the car to remove the starter.
I also replaced the clutch line w/ stainless steel line and use ATE super blue.
Impressions:
1. Pedal feels a lot harder (heavier)
2. Precise feeling (when you press and depress)
3. Faster clutch engagement compared to stock (no delay)
4. Now I can shift better.
5. If you think brake lines make brakes feel better then it's the same thing.
Worth it to do?
Tell you the truth for the time that I spent and the result, it's not really worth it (cause you have to remove the starter)
But hey.. cheap mods for a better clutch feeling while having fun installing back the damn STi intercooler - Priceless.
salaki is offline   Reply With Quote
Privacy Policy
