Old 07-14-2008, 12:15 PM   #1
Car: Blue 06 sti
Send a message via AIM to mango143 Send a message via MSN to mango143
Default turbo timer..help
I have 06 subaru sti and i got greddy full auto timer and i have no clue how to install the darn thing. cuz its in japanese....so please help...thanks
mango143 is offline   Reply With Quote
Old 07-14-2008, 12:20 PM   #2
i eat cones
Fav Mod: 18x8
Trader Rating: (21)
Default Re: turbo timer..help
having a turbo timer is not needed, but besides that, it has been covered 300 times. search around for info on it.
Old 07-14-2008, 04:29 PM   #3
Fav Mod: Motor Mounts
Yep, sell it...its worthless and wastes $$$.
Old 07-14-2008, 10:45 PM   #4
Car: Blue 06 sti
but what i heard from pro is that even tho the cooling is NP but there is still boost left in there for it no leave the chamber so it should need TT...im confused...
Old 07-15-2008, 05:41 AM   #5
FWIW...I have 70K on my 04...most of that stage 2 and I havent had any problems with it. Subaru designed the engine to not need one.
Old 07-15-2008, 05:51 AM   #6
abracious
Fav Mod: Track time
This person is NOT a pro. Never trust a word they say again.
Old 07-15-2008, 05:53 AM   #7
Fav Mod: T2s and Recaros
boost still left in there? that guy doesn't sound like a pro at all.
turbo timers are used to cool the oil going through the turbine off after hard use. they keep the engine running to run the oil through the system to cool it so that the bearings in the turbo don't get coked up from the high heat of the turbo as the car sits there parked.
on a subaru, the turbos are water and oil cooled. this means that the turbocharger has coolant running through it to reduce the heat of the turbo. consult your manual and you'll see that unless you've been beating on the car hard, the coolant does an adequate enough job of coolign the turbo so that the oil inside of it doesn't get hot enough to coke up.
in summary, sell the turbo timer to a guy with a DSM and chalk it up to listening to the wrong person.
Old 07-15-2008, 05:56 AM   #8
abracious
Fav Mod: Track time
You're so much nicer than me.
Old 07-15-2008, 07:12 AM   #9
I figure either that "pro" is an imbecile, or he's trying to rip this guy off and play on his lack of knowledge.
