Old 07-10-2008, 08:07 AM   #1
Car: OBP 05 WRX STi
Fav Mod: BC Racing Coilovers
Default bc racing coilovers & camber bolts
hey its my first time doing coilovers w/ rear camber bolts and i found a "how to" for the bc racing but it doesnt say anything about the camber bolts for the rear? anyone know how to?? & i also read that the brake lines might leak????....
sersiny is offline   Reply With Quote
Old 07-11-2008, 05:54 AM   #2
Car: 07 Subaru STi
Fav Mod: Coilovers/Tune
Send a message via AIM to IGoFast1589
Default Re: bc racing coilovers & camber bolts
I'm installing my BC's this weekend hopefully and would like to know this also. Can you give me that link for the how to on the BC's?
IGoFast1589 is online now   Reply With Quote
Old 07-11-2008, 06:06 AM   #3
Car: OBP 05 WRX STi
BC Racing Coilover Install
this should help but i still need help w/ the camber bolts....
Old 07-11-2008, 12:05 PM   #4
Fav Mod: All of them
As far as I understand camber bolts in the rear you replace the top strut to knuckle bolt with it. Let the coils settle for a few days and get an alignment. Its as easy as taking one bolt out and putting yours in. The front has a camber bolt so you can compare that way. Just out of curiosity what camber are you trying to get in the rear? I got -1 front and rear with my BCs and no rear camber bolt.
The brake line question I have no idea. Mine didnt leak and the 5 or 6 other guys I know with these didnt leak either. Just be gentle when removing the old struts.
IGoFast - im not too far from you if you want some help puttin these in. Only problem I had was one bolt was stuck on like crazy causing me to snap 2 sockets, an adapter and I bent my breaker bar. Impact sockets did the trick.
Partysub is offline   Reply With Quote
Old 07-11-2008, 12:35 PM   #5
Car: 05 WRX STi
Fav Mod: RCE Tarmac-2's!
EDIT: Mis-read OP. nvm.
JPotter is offline   Reply With Quote
Old 07-11-2008, 08:45 PM   #6
Car: 07 Subaru STi
That would be awesome thanks! They were supposed to be delivered yesterday, but no one was home to sign for them and now I will have to track them down OR wait until they are going to drop here off here again.
Old 07-12-2008, 05:34 AM   #7
just let me know man. Always willing to help.
Old 07-12-2008, 06:16 AM   #8
Car: 07 Subaru STi
Thanks! So I spoke to UPS and I am going to have to pick up coilovers on Monday or wait for their second delivery attempt. I'll probably end up installing them over next weekend at my friends place in Ridgefield CT, but if you want to stop by you may do so.
Old 07-12-2008, 09:24 AM   #9
Ok, ill stop if you want help. Im helping another friend with a brake job on sat so if you are still stuck on sunday let me know.
Old 07-12-2008, 12:59 PM   #10
Fav Mod: Perrin 30r Kit
the top bolt of the strut is the camber bolt. you will have to remove the stock one to get the stock struts off anyways (like partysub said).
installing the coilovers will be cake, especially since you dont have to remove the springs on the stock struts (like if you just got springs, you would need a spring compressor to get them off). all you have to do is remove the bolts on the top of the strut and bottom, take out the whole entire strut assembly with the spring on it, and put in the new one. very simple. just make sure you spray down the bolts with some pb blaster to loosen them up so you dont strip them or anything.
