Old 07-02-2008, 11:37 AM   #1
Car: Black 2007 STi Sex
Fav Mod: WOT!!! =P
Default How to turn head lights off when parking break is down
Cant seem to find this thread anywhere, I noticed that my 07 ALWAYS has the headlights on unless the parking break is up, before I go digging in and looking for the parking break switch has anyone already written a DIY for this? or am i retarded and there is a normal way of turning them off?
EDIT: found it, here it is
http://www.toyotabg.net/files/dtr2_640.jpg
xpsychovampyrox is offline   Reply With Quote
Old 07-02-2008, 11:40 AM   #2
Car: 07 STi
Fav Mod: catless dp+GReddy
Default Re: How to turn head lights off when parking break is down
thats the DRL. Theres a lot of DYIs on how to disable the DRL
kaazuumaa is online now   Reply With Quote
Old 07-02-2008, 11:53 AM   #3
i eat cones
Fav Mod: 18x8
Trader Rating: (21)
yeah, there is a diy mod. its around somewhere.
Old 07-02-2008, 12:03 PM   #4
Fav Mod: WOT!!! =P
there are a couple, cant find one with working pictures
Old 07-02-2008, 12:17 PM   #5
Why out of curiosity? It makes you more visible to other drivers and less chance you will get hit by some idiot not paying attention.
Biznatch231 is offline   Reply With Quote
Old 07-02-2008, 12:30 PM   #6
Fav Mod: AP
2007 DRL disable different than 2006?
Its like post 51 by user altezza
You cut the green/yellow wire in the harness under the steering column. There are plenty of pictures in the thread
Your user info on the left doesn't say what year you have. These instruction are for 07 (and I think 06). I think the 04-05 the wires you need are behind the glovebox instead (can't remember specifically but its mentioned a coulple of times in the link above)
Also I know its hard to go cutting wires on your perfectly good car and I also wrestled with this but seriously it only takes a couple of minutes. The only problem is; if you're a big guy like me; contorting your body to be able to look up under the dash
Oops just reread your first post and say you were talking about an 07. The above link is the one for you
Old 07-02-2008, 12:32 PM   #7
Car: 05 STi |STOCK|
Fav Mod: Not a post 07 sti fan
So when did they start the DRL's in the STI's? I know mine doesn't have them but maybe they're just disabled. Not that I want them or anything I'm just curious.
chargedvette02 is offline   Reply With Quote
Old 07-02-2008, 12:58 PM   #8
Fav Mod: WOT!!! =P
ok found it...had to read through the whole thread so here it is
Old 07-02-2008, 01:00 PM   #9
Fav Mod: WOT!!! =P
lol didnt see the posts above but yes post 51 is clean and correct. I have an 07, just had it for a couple of days updates will come soon.
Old 07-02-2008, 01:12 PM   #10
Car: 05 Subaru WRX STi
Fav Mod: EVO Recaro Seats
Send a message via AIM to IUSTi
Definetely know the 04/05 didnt come with it. I think they started in 06 but don't quote me on that.
IUSTi is offline   Reply With Quote
Old 07-02-2008, 03:29 PM   #11
Car: obp 07 sti
Fav Mod: spt intake and exhaust for now
i like it cause it tells me when my front differential is disabled so i can go drifting jk
bcfsc is online now   Reply With Quote
Old 07-02-2008, 06:06 PM   #12
Car: 05 STi |STOCK|
Thanks for the info.
Old 07-02-2008, 06:28 PM   #13
Car: 2007 OBP/Gold Wheels
Fav Mod: Prodrive Mudflaps
Don't go cutting any wires. You can disable the DRL's by unplugging some wires behind the glovebox. I did it, but then reconnected them. I was hoping to be able to use the city lights (the first click up on the wand) but it would dim everything in the dash which was a pain in the rear.
It's really important to have some sort of lights on up front during the day. It really makes a difference preventing people from pulling out in front of you.
Here is the thread that explains how to disable the DRL's without clipping any wiresIt seems like the pictures were removed but maybe you can contact the OP and have them send you the photos or repost them)
Old 07-02-2008, 06:37 PM   #14
Fav Mod: AP
EDIT: sti2relaxxin, dude if you read my post before I edited it then please ignore it. I'm an @sshole...its been a long day at work
Old 07-03-2008, 06:49 AM   #15
Fav Mod: WOT!!! =P
Ok so I did this last night while i was letting the car cool before my super messy oil change. Anyway it works fine, HOWEVER when i was down there I noticed TWO green Connectors, each with one wire in there, and it was unplugged. I decided to plug them back together and see what they were. As soon as I plugged it back in and turned the power on (not the engine) my engine fan started turning on and off.... any ideas of what this is and whether it should be plugged in?
