Old 06-25-2008, 09:14 PM   #1
Car: silver 05 wrx sti
Question down Pipe
What is the easyest way to take off the stock down pipe?
Moisti is offline   Reply With Quote
Old 06-25-2008, 09:33 PM   #2
Car: '05 WRB STi
Fav Mod: JDM magnectic drain plug yo
Default Re: down Pipe
A little time and patience. There's really not much to it besides the bazillion amount of bolts on the stock turbo heat shield. Just use a liberal amount of penetrating oil and be careful with the o2 sensor
Evan is offline   Reply With Quote
Old 06-26-2008, 11:37 AM   #3
Question Re: down Pipe
Do you have to unbolt the turbo?
Old 06-26-2008, 04:03 PM   #4
Car: suebahroo
Fav Mod: KB SSS
no you dont have to unbolt the turbo, but taking off the intercooler makes it an easier job. Spray some PB Blaster on the downpipe bolts and let it sit, you should be all good after that. good luck
dangk is online now   Reply With Quote
Old 06-26-2008, 05:46 PM   #5
What about the up pipe?
Old 06-26-2008, 05:46 PM   #6
Fav Mod: The Newest One!
No345
Old 07-03-2008, 06:32 AM   #7
Car: Silver 04 wrx
The up-pipe is the biggest PITA job, involves jacking up the motor and everything.
04wrx350hp is offline   Reply With Quote
Old 07-03-2008, 10:07 AM   #8
Car: 04 subaru sti
Fav Mod: 35r turbo kit
its really not hard as hard as he states..but you do have to jack the motor up , but really only takes another 5 minutes.
will12345 is offline   Reply With Quote
Old 07-03-2008, 11:56 AM   #9
No you dont have to jack the motor up. Yes it can make the install/life much easier, but you do not have to.
Old 07-03-2008, 12:00 PM   #10
Car: My06 WRB w/ Gold STi
Fav Mod: JDM Headlights and JDM Rear Fog
You do not have to jack up the motor. I have heard that you do but i have done dozens of upipes and I have never jacked up the motor. I have even done a uppipe from start to finish in about 45 minutes the ones that give me a little bit of trouble usually take me about an hour and a half to do.
WRB Kid is online now   Reply With Quote
Old 07-03-2008, 07:11 PM   #11
Young and restless
Car: 2005 Aspen White STI
Fav Mod: Torque
Send a message via AIM to MikeO Send a message via MSN to MikeO
You don't need to worry about the up pipe. In the STI it doesn't have a restricting cat.
Just carefully take off the topmount intercooler and be sure to remember how you took it off, cause it can be a PITA putting it back on if you don't do it the same way connecting the hoses and such.
Once the intercooler is off you have alot of room above and below the downpipe to reach all of the bolts. The most PITA bolt is the one that is on the bottom side of the DP/wastegate area and it's a bit hard to get to with a bigger socket.
Definitely make sure you use some WD40 or lubricant to loosen the bolts if they look rusted.
Lastly, you might have some trouble getting the new DP back on the same way you took it off, the fitting the bolts can be a little tricky in that tight space. Make sure when you're attaching the DP back to the turbo not to pinch the gasket in any areas, otherwise it will cause a leak.
Then just stick your top mount back on, connect the hoses etc and you're done.
Also if you're installing a heat shield, make sure you don't forget to do that BEFORE you put your top mount back on.
Good luck.
MikeO is offline   Reply With Quote
Old 07-04-2008, 05:15 AM   #12
^^I can agree the first time you do a DP install you might want to take off the TMIC. But the second time around I didnt bother. Just put some never seize on the bolts before you put the new DP on. Then next time you have to take it off, it will be a cake walk and wont have to take off the TMIC to get the bolts off.
Old 07-04-2008, 12:16 PM   #13
Car: Silver 04 wrx
O thats nice to know. Most of the reason I havent done the up pipe yet is because I didnt feel like going through the hell-ish install.
Old 07-04-2008, 02:50 PM   #14
Car: 2004 STi Blue
im doin my downpipe install aswell. is there a DIY? or Write up?
04_Sti_Blue is offline   Reply With Quote
