| | #21 |
| STI Driver Feedback Score: 1 reviews Car: 06 wrx ltd vf34 Fav Mod: JTAG Location: IL Posts: 295
IWSTI Addict since: Dec 2006 | best write-up ever!! |
| | #22 |
| Junior STI Driver Feedback Score: 0 reviews Car: UGM 07 STi L #95 Fav Mod: oil drain valve Location: Jacksonville, FL Posts: 189
IWSTI Addict since: Oct 2007 | I was unable to get all 8.1 quarts of coolant into the system. Is the reservoir tank included in the 8.1 quart coolant system total? The car seems to be running fine and the temperature ranges from 180º-185º F while driving and up to 196º F idling at a stoplight for over a minute. This was an excellent write up! Thanks for taking the time. Last edited by STISubSilver; 07-25-2008 at 04:45 AM.. |
| | #23 | |
IWSTI Addict since: Oct 2007 | Quote:
| | #24 | |
| The Next Petter Solberg Feedback Score: 0 reviews Car: Blue 07 WRX STI Fav Mod: Soap Location: Winston Salem, NC Posts: 853
IWSTI Addict since: Apr 2007 | Quote:
. This is why the first post has a System Overview.Just be sure to check your fluid levels at the Filler Tank and Reservoir Tank when at the gas pump or house (when the engine is cool enough). Sometimes, the levels will drop a little bit more. Last edited by STI Sibb; 07-25-2008 at 10:19 AM.. | |
| | #25 |
IWSTI Addict since: Oct 2007 | Have you used any other coolant products such as MoCool? |
| | #26 |
IWSTI Addict since: Apr 2007 | I personally haven't as this is the first time I've changed my coolant. If you do a search, this topic is probably covered somewhere else in the forums. If not, start a thread and you'll get plenty of response. |
| | #27 |
IWSTI Addict since: Oct 2007 | Not much found yet. But I am keeping an eye out for anyone who found any advantages for using this stuff. I did find the spec sheet for it though. Thanks. |
| | #28 |
| Spec C Club Feedback Score: 1 reviews | I followed this to the T, but was only able to get about 7 quarts of fluid out. About the same went back in. It looks like a quart was trapped in there somewhere. I let it drain for about 45 minutes. I backed out the drain plug at least 6 turns. Any ideas. I'm guessing there was some fluid in the hoses... |
| | #29 | |
When you say 7 quarts, do you mean 7 liters? Last edited by STI Sibb; 08-12-2008 at 06:33 AM.. | |
| | #30 |
| Spec C Club Feedback Score: 1 reviews | 6.5 Quarts (6.15 Liters) came out. That includes what came from the reservoir tank, which was at the full mark. I'd say about the same amount of new coolant (including the conditioner bottle) went back into the system. That would leave about 1.5 Quarts that never came out. That just seems like a lot of old fluid to leave in there. I'm thinking about changing it again since I never opened a whole gallon of the coolant. |
| Thread Tools | |
