| | #101 | |
| Junior STI Driver Feedback Score: 0 reviews
Car: White 05 STI Fav Mod: Aerocatch hood locks Location: Portland OR Posts: 177
IWSTI Addict since: Sep 2007 | Quote:
That is how I get to it anyhow. I have equal length synic headers + skid plates, I know what you mean by no room. Sean | |
| | #102 |
| Grassroots STI Racer Feedback Score: 3 reviews Car: '05 WRB STi Fav Mod: GT52 Turbo Location: back in Abilene, TX :( Posts: 558
IWSTI Addict since: Dec 2006 | Awesome, thanks man, that didn't occur to me. Shouldnt be much of a problem as most of the fender liner is held on by zip ties thanks to the FMIC |
| | #103 |
| STI Driver Feedback Score: 2 reviews Car: 06 White/Gold STi Fav Mod: The Driver Mod Location: Southern, AL Posts: 200
IWSTI Addict since: Aug 2005 | Is it just me or does this simple process seem to be getting WAY over complicated? As for slowly adding coolant to the small resivore on top..... Why dont we just fill up the radiator, then add coolant to the recivore on top, then to the overflow..... put the cap back on the radiator..... leave the cap off the top resivore, start the car and let the coolant cycles through the block to burp, and add as needed to finish? |
| | #104 | |
| S204 Racer Feedback Score: 0 reviews Car: '10 VW GTI Location: Montgomery, Al Posts: 3,299
IWSTI Addict since: Apr 2006 | Quote:
For me, it took exactly two gallons, I've had to add no more since the two bottles of premix Peak I purchased were emptied and in the reservoir it's at the "full" line. Has been for months since I did this. | |
| | #105 | |
| The Next Petter Solberg Feedback Score: 0 reviews Car: Blue 07 WRX STI Fav Mod: Soap Location: Winston Salem, NC Posts: 853
IWSTI Addict since: Apr 2007 | Quote:
You can also do a continous pour as some describe, but you need to pay attention to the temperature of the block. When the coolant is first added, there is a lot of air in the system that causes it to heat up rapidly. You would overheat the car quickly if you're not careful. The writeup is intended to help someone that is changing their coolant for the first time. Last edited by STI Sibb; 08-20-2009 at 07:37 PM.. | |
| | #106 |
IWSTI Addict since: Apr 2006 | Yeah, but keep in mind that the oil in the engine also provides cooling for the engine. Just as long as you keep adding coolant the second more can be added, I don't think there's anything to worry about. When you're in the process of refilling the coolant air pockets are basically unavoidable. |
| | #108 |
| Junior STI Driver Feedback Score: 0 reviews Posts: 177
IWSTI Addict since: Feb 2004 | Hey guys, I'm going to do this today. I want to try to get rid of as much of the green coolant as possible since I will be using the new blue version. If I have everything drained, can I just keep pouring in the distilled water to flush it out and this for a little bit, THEN Screw the drain plug and fill it with new coolant? Has anyone done this? |
| | #109 | |
| | #110 |
| Lurker Feedback Score: 0 reviews Car: Aspen White 2002 WRX Fav Mod: All of them! Location: Bellingham Posts: 2
IWSTI Addict since: Jun 2007 | Can you fill it back up with water from a garden hose to "flush" our the coolant before you fill with actual radiator fluid? |
| Thread Tools | |
