Old 06-19-2008, 08:31 PM   #1
Car: Black, 04 WRX STi
Default Steering rack bushing install gone horribly wrong
Well I checked out all of the installs on the topic and thought it seemed easy enough. It actually seems easier than some people say. Well my problem is that 2 of the rack bolts broke off upon removal, leaving a fair amount of bolt still in the frame. Normally this is no big deal, but neither of them could be extracted. Broken bolt #1 was literally drilled out to the point where there was nothing left, but it still wouldn't break apart and fall out. So the hole was drilled out slightly larger and re-tapped for a bigger bolt.
Broken bolt #2 was moving along nicely until it snapped off the hardened extractor that was attempting to remove it. Now there is a hardened extractor inside a seized bolt.
I don't know that I trust the re-tapped hole and getting this extractor out hasn't gone very well. My how to is more of a request for how to get myself out of this mess. Any help or thoughts are greatly appreciated. I have a good friend who is a master mechanic and has been helping me try to resolve this and he has never seen bolts that won't come out or require this much effort to remove.
One thought I had is to replace whatever crossmember the rack mounts to. But the dealer can't figure out the right part number.
Thanks!
TFocker is offline   Reply With Quote
Old 06-19-2008, 10:38 PM   #2
Car: 05 CGM STI w/goldies
Fav Mod: Advan A048's
Default Re: Steering rack bushing install gone horribly wrong
sorry to hear that, that sucks big time! i just did that mod on my '05 without any problems, it went much easier then i thought it would. i'm guessin you will have to replace that crossmember that the bolt and extractor are stuck in, i don't think any drill bit will be able to drill out a hardened extractor. good luck with it!
crf-sti is offline   Reply With Quote
Old 06-20-2008, 05:46 AM   #3
Car: 06 Subaru WRX STi
Fav Mod: Cobb Xaust!
man that sucks... i was thinking about changing this myself... but idk anymore...
I guess your best bet is email jamie at subarugenuineparts.com and she will help you find the part #..
good luck!
oscargarza88 is offline   Reply With Quote
Old 06-20-2008, 07:26 AM   #4
Fav Mod: TBE
Exact same thing happened to me! Basically what I did was remove the nut on the top side of the cross member with an air hammer. Those bolts thread into a nut welded onto that cross member and basically sit in a pool of water when it gets wet out causing a ton of rust to accumulate.
I took an air hammer and hit the bottom of the bolt with it and it will broke the welds on the nut. Then I welded grade 8 nuts back on and used grade 8 bolts. It was a lot of work but it was really the only thing that could fix it like new.
Old 06-20-2008, 02:12 PM   #5
Fav Mod: All of them
one of mine snapped so I welded a washer and nut to the snapped off bolt and backed it out. It took about 4 tries but it finally came out.
Partysub is offline   Reply With Quote
Old 06-20-2008, 03:15 PM   #6
Car: 04 STI JBP
Fav Mod: LC
I recently ran into a similar problem at work, and i used a small carbide burr to ream out the extractor then drilled the rest of the way... Best of luck.
Mustangkilla is offline   Reply With Quote
Old 06-20-2008, 08:00 PM   #7
I'm guessing you had to remove the crossmember to do this? How big of a pain is it to remove?
Old 06-21-2008, 03:27 AM   #8
Dji
Car: 04 White STi
Send a message via MSN to Dji
I'm doing my steering rack today, I wish this will not happen.
Dji is offline   Reply With Quote
Old 07-19-2008, 03:04 PM   #9
Car: 04 JBP WRX STi
Fav Mod: ProTune by Hill at Agile
You can put a nut a locking nut up behind it and use a bolt. We busted one of mine when we did it a long time ago. I was soooo bummed. It seemed to take forever to get that nut/bolt started, but eventually got it.
Sti491 is offline   Reply With Quote
Old 07-19-2008, 11:47 PM   #10
Actually the solution ended up being really simple, hitting the bolt with an air hammer and breaking the welded nut off. It's actually just as good, if not better than new. It just sucks that we spent forever trying to drill out and re-tap the holes. Thanks for all the input!
Old 07-21-2008, 04:36 PM   #11
Car: White 06 STi
Fav Mod: Forged Bypass
Send a message via AIM to ilami01 Send a message via Yahoo to ilami01
I stripped one bolt on my steering rack, any suggestions? Its been like this for a long time ha
ilami01 is offline   Reply With Quote
Old 07-21-2008, 08:19 PM   #12
same thing I did, break the welded nut off and put a new nut and bolt on it.
Old 07-21-2008, 10:15 PM   #13
Car: 06 STI UGM
Fav Mod: (o)(o)
I have been thinking about getting a WL searing rack for my 06 as I hear it's a wonderful mod that a lot of people recommend...
It's not that expensive ther I don't think...
Does anyone have any pics so I can visually see what you guys are talking about?
Thanks,
Jay
jaydow11 is offline   Reply With Quote
Old 07-24-2008, 12:17 PM   #14
Car: 06 STI UGM
Fav Mod: (o)(o)
Thanks,
Jay
Anyone?
Old 07-25-2008, 05:43 AM   #15
Fav Mod: hammer down!
Here's a pic of what the left (driver's) side mount looks like. There are 4 bolts here. There are also 2 at the other end of the rack that hold a bracket in place. I don't know which ones tend to rust first...
