Old 06-04-2008, 08:28 AM   #1
Car: JBP 2004 STi
Fav Mod: Ohlins FPS
Default Bring your HID wisdom.
Ive done a bit of research and now only more confused then when i started.
I want to get a HID kit for my car(2004 STi). Now apperently STi's come stock with HID's... but i want the bright white/blue light.
Do i need a full HID with wire harness', ballast and new bulbs...
or
Do i just need replacement bulbs...
If some STi's came with HID's and other didnt, how do i check what my car is equipped with.
How can i find out what kind of bulb i need...
ooWRX_STioo is offline   Reply With Quote
Old 06-04-2008, 09:00 AM   #2
Car: wtb 07 STI
Default Re: Bring your HID wisdom.
Hey, all you need to do is get a bulb. You currently have 4300K on your car right now. If you want a bright white/blue color you will need the 6000K range no more no less. Your bulbs are D2R i believe.
T_A_C_H is online now   Reply With Quote
Old 06-04-2008, 09:10 AM   #3
Car: JBP 2004 STi
Fav Mod: Ohlins FPS
Does anyone know where i can check what kind of bulbs i need (04 STi)...
I know its on the Sylvania site somewhere...
Old 06-04-2008, 09:12 AM   #4
Car: '07 Obsidian Black
Fav Mod: Stage 2 + Protune
Cars that come stock with HIDs will have the capability to replace their D2S bulbs (if your car has a projector) or D2R bulbs if your car uses a reflector. Users can vary the color by going to different temperature bulbs with varying K (Kelvin) values. Keep in mind that whiter light will have brighter output and bluer lights will be less brighter (this is different than the color temperature).
If your car did not come with HIDs, then you will need the whole kit (ballast/ignitor, wiring harness & appropriate bulbs for lamp housing).
There are many pros/cons regarding HID conversion kits. I'd say read up online. Beware of cheap kits. Daniel Stern of Daniel Stern lighting is a pretty good resource. He helped me when we upgraded to HIDs on our B5.5 Passat (upgraded to euro OEM HID units).
Daniel Stern Lighting Consultancy and Supply
Good luck!
karleric is offline   Reply With Quote
Old 06-04-2008, 09:13 AM   #5
Car: JBP 2004 STi
Fav Mod: Ohlins FPS
Thanks so you much Karleric, finally someone was able to clear this up for me.
2004 SUBARU WRX STI
Low beam headlamp
HID-D2R (Us Model)
H1 (Canadian Model)
High beam headlamp
9005
9005SU Silverstar ULTRA for Ultra Night Vision - The Whitest and Brightest Halogen
9005ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen
9005XV XtraVision Halogen - The Brighter Light
9005CB Cool Blue Halogen - The Whiter Light
Parking light
168
168LL Long Life Upgrade: Up to twice the life of the standard lamp
Front turn signal
7440
Rear turn signal
992 (7440A)
Tail light
7443
Stop light
7440
7443
High mount stop light
921
921LL Long Life Upgrade: Up to twice the life of the standard lamp
Fog/Driving light
H3-55W
H3ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen
License plate
168
Back up light
7440
Front sidemarker
168
Rear sidemarker
168
Ash tray
74
Map light
DE3175
Dome light
DE3175
Trunk/Cargo area
921
Can anyone confirm these findings...
Old 06-04-2008, 09:24 AM   #6
If your '04 does indeed come with HIDs, then all you'll need is a pair of D2R bulbs of your temperature choice.
Old 06-05-2008, 12:11 AM   #7
Car: 05' OBP STi
Fav Mod: Stage 2
Not sure but correct me if i'm wrong. I see he's from Canada and I thought that STi's out of Canada didnt come with HID's thought I saw that somewhere. ask Lightwerkz hes the go to man for your lighting source!
STiKE20 is offline   Reply With Quote
Old 06-06-2008, 04:45 AM   #8
Car: JBP 2004 STi
Fav Mod: Ohlins FPS
I did some more research and your correct. The bulb list above is correct except for the lowbeams. Canadian models dont have HID low beams, its an H1 Halogen around 4000k.
A cheal alternative to HID's in this case will just be a bulb upgrade. For about 45$ you can get H1 6000K bulbs which look quite nice. Tomorrow morning Im going to pick some up, and tomorrow night ill try and get some shots in. Ill post the befores and afters.
Old 07-21-2008, 09:02 AM   #9
Car: 04 Aspen White STi
Fav Mod: exhaust powered intake
are d2r and d2c the same bulb?
B4RSTiwsnc is offline   Reply With Quote
Old 07-21-2008, 09:22 AM   #10
Car: JBP 2004 STi
Fav Mod: Ohlins FPS
im not 100% sure, but i dont think they are.
can anyone confirm, and/or state whats different about them?
Old 07-21-2008, 10:17 AM   #11
Car: wtb 07 STI
Look at post # 4 . D2R is reflective, Which means you dont have a projector in your headlight, D2S means that you have a projector lens and it can shine a beam of light to the road ahead. D2R needs to be reflected off of to shine ahead. Hope this helps.
Old 07-21-2008, 10:18 AM   #12
I just installed them and they fit fine. Only difference was a 3 notches on the ring instead of 2
Old 07-21-2008, 04:31 PM   #13
Car: White 06 STi
Fav Mod: Forged Bypass
Send a message via AIM to ilami01 Send a message via Yahoo to ilami01
ok now tell me how to do it to my 2006, just need the 6000k bulbs?
ilami01 is offline   Reply With Quote
Old 07-21-2008, 05:23 PM   #14
all you need is d2s bulbs whatever Kelvin temp you want stock is 4300k
Old 07-21-2008, 10:19 PM   #15
Car: 06 STI UGM
Fav Mod: (o)(o)
I put a full HID kit on my wife's Acadia and went with 5000k bulbs. Although they are quite blue and look really nice, I do notice that they produce quite a bit LESS light than a 4300k bulb...
I didn't think that 700k would make that much of a difference but it does...
If I was to do it over again, I would stick with the 4300k bulbs that just about all stock cars with HID's come with.
Cheers,
Jay
jaydow11 is offline   Reply With Quote
