Old 05-16-2008, 04:21 AM   #1
Car: collecting toys
Default Bottom nut
Ok so I've got the front drivers side strut off and I'm trying to remove the bottom nut from the strut and I have broken it free bur now it just spins with the "bolt" it's attached to when I'm holding the strut shaft. If I'm not holding the strut then the whole assembly spins.
Help Please.
darthtater is offline   Reply With Quote
Old 05-16-2008, 05:59 AM   #2
Titanium Member
Fav Mod: Bill
Default Re: Bottom nut
Help Please.
OK, I've not done this but....
Look to see if there is a alan head (hex) in the center. If there is you can hold the center still with an alan head wrench and turn the nut with an box end wrench.
Or hit the nut with an impact driver.
Old 05-16-2008, 10:23 AM   #3
Thanks, problem solved. took it to a shop, guy used an impact came right off. And the best part he didn't try to charge me.
