Old 05-06-2008, 03:03 PM   #1
Car: 02 WRX faux STi
Fav Mod: roof rack
Thumbs up Short block assembly
you will need,
a pair of very long needle nose pilers
6/12 point metric socket
14mm allen socket (piston wrist pin access)
torque wrench
ring cutter /dremel
feeler guauge
vernier calipers
bore diameter caliper
ring compressor
dead blow hammer ( plastic/ hard rubber)
so lets start measuring things.
place main bearings in case halves.
torque to specs.
measure the distance between bearing surfaces, make sure not to scratch.
then measure the crank journal.
compare to two.
this main bearing clearance.
second connecting rods
place connecting rod bearings into connecting rods.
torque to specs.
then measure the rod journal on crank.
compare to two.
this connecting rod bearing clearance.
inspect case halves & clean mating surfaces.
place all o-rings in their receses
fuji-bond case halves
assuming crank & connecting rods are good.
assemble crank assembly use plenty of assembly lube
place crank bearings in case halves
carefully place crank assembly into 1 of the case halves
assemble case halves.
again torque to specs.
third pistons & rings
measure cylinder bore in three places from top
of bore down into cylinder.
now measure piston in approximately the spacing.
depending on how much boost the piston to cylinder wall
clearance will accomodate.
again follow manufacturer recommendations
match piston to cylinder while maintaining piston to cylinder wall
clearance.
squirt oil into cylinder to coat.
there should some mark to denote the top of the rings
first read manufacturer's recommendation for ring gaps.
lay out all the rings by type, top, middle, bottom (for location description)
top ring
use one of your pistons (carefully) and press into cylinder the depth of top
ring land.
use feeler guage to determine ring end gap.
if too small grind off end to desired length
hopefully things measure out to desired measurement (top ring gap)
repeat process for middle ring
bottom ring
place thin/scrapper/thin ring
after placing all the rings in their grooves.
place ring compressor over the piston
tighten and compress rings
squirt oil around piston & ring compressor.
place appropriate piston into it's cylinder bore.
tape with dead blow hammer handle until piston
rings have completely driven into cylinder bore.
stop when piston is right at top dead center or flush
with the top of the case.
slowly rotate crank until rod comes up in cylinder.
insert piston wrist pin through access hole.
install piston wrist pin c clips.
repeat process for other pistons.
there you short block / case halves are done.
if i overlooked anything chime in.
jaxscuby is offline   Reply With Quote
Old 05-08-2008, 05:15 PM   #2
Titanium Member
Fav Mod: Bill
Default Re: Short block assembly
Originally Posted by jaxscuby View Post
you will need,
torque wrench
ring cutter /dremel
feeler guauge
vernier calipers
ring compressor
torque to specs.
compare to two.
torque to specs.
compare to two.
clearance.
top ring
ring land.
bottom ring
Holy crap Ben!
Old 05-08-2008, 05:21 PM   #3
Car: 07 GDB-G WRB STi
Fav Mod: shift knob
A post in dire need of some pictures
rs_wrx_sti is offline   Reply With Quote
Old 05-10-2008, 04:43 AM   #4
Fav Mod: roof rack
when i come home for vacation i'll post pictures of
my ej22t to ej257...
Old 07-19-2008, 12:51 PM   #5
The Stig II
Fav Mod: EFI Logics tune
Pics???
jnprn2003 is offline   Reply With Quote
Old 09-01-2008, 09:58 AM   #6
Car: 2002 MBP WRX
Send a message via AIM to Northmiler89 Send a message via Yahoo to Northmiler89
Originally Posted by jnprn2003 View Post
Pics???
Please
Northmiler89 is offline   Reply With Quote
