Old 04-15-2008, 07:24 PM   #1
Car: 05 WRB "STI"
Fav Mod: hugeee turboooO!
Default how to install triple gauge pod in dashboard?
hi guys' any an idea?. coz' mine is in driver side,i'd like to replace in by the clock is..thanks in advance!
STInoel18 is offline   Reply With Quote
Old 04-15-2008, 08:07 PM   #2
Car: 06 sti
Default Re: how to install triple gauge pod in dashboard?
The clock piece should just pop out. Then unscrew the clock from the plastic piece. I would leave the clock plugged in though underneath the pod because it runs the airbag and abs, i believe.
sakisst is offline   Reply With Quote
Old 04-18-2008, 12:12 PM   #3
Car: 05 WRB "STI"
thanks sakisst! that helps!
Old 04-20-2008, 04:54 PM   #4
Car: Blue 04 WRX
Can you explain this as it doesn't make a whole lot of sense to me. If the current is going to the clock, and the clock is removed, there will simply be no power demand from the clock. How would this affect the abs and airbags?
wrx04fast is offline   Reply With Quote
Old 04-20-2008, 04:57 PM   #5
Fav Mod: Ricer Flyby
theres an airbag light on 06+ models in which it matters. It says "passanger airbag OFF/ON" and it lights up. If you take off the clock, then the airbag light will go on in the dashboard because it broke the circuit and the airbag would be messed up.
WESTI is online now   Reply With Quote
Old 04-20-2008, 04:59 PM   #6
Car: Blue 04 WRX
Oh, I see, so if I'm doing this on my 04 (which is the install that I am doing next), I don't need to worry about airbags or abs? There isn't any airbag lights on the clock piece.
Thanks for the explaination, this makes sense to me now, and it sounds like it could be very detrimental to unplug this on the 06+ models.
Old 04-20-2008, 08:00 PM   #7
Fav Mod: JDM STi Performance Muffler
Yup pre-06's don't have to worry as there's no "Pass Airbag light" in the clock. Also, if the airbag light on the instrument cluster comes on, NONE of the airbags in the car go off in the event of an accident. (Which is pretty stupid IMHO)
300hp@6000rpm is offline   Reply With Quote
Old 04-22-2008, 06:47 PM   #8
Car: 05 WRB "STI"
i see..i hope is not PITA..
Old 04-24-2008, 05:23 PM   #9
STI Guru
Fav Mod: Whooshing sounds
Start with the front of the clock, it will pop out, just work slowly.
Peleg is online now   Reply With Quote
Old 04-25-2008, 05:48 PM   #10
Car: 06 sti
Yeah whole process is pretty easy. The hardest part is wiring the gauges for power and illumination. As Peleg says just work slowly and dont rush anything and it should be pretty simple.
Old 04-26-2008, 11:13 AM   #11
Car: 05 WRB "STI"
thanks alot guy's!
