Old 04-09-2008, 07:31 AM   #1
HowTo Contributor
Car: 05STi - Meth Addict
Fav Mod: ze FP green
Send a message via AIM to ProdriveREX Send a message via MSN to ProdriveREX
Lightbulb How To: RED LED Upgrade for 04-05 HID Leveling Switch
Here is how to do this mod correctly
Tools/parts needed:
1. 3mm Red Led (1.7v, 20mA, 150-600mcd focused light output) x4
2. Soldering Iron
3. Small wire cutters
4. Small screwdriver to open switch up
5. Q-tip and Acetone
You can buy 3mm LED in any electronics shop, just make sure they are somewhere in 150+ mcd range (Higher the mcd number, brighter the LED)
______________
1. Pull the Knob off, it will come right off
2. Use small flat screw driver to open up the switch. Two tabs on each side.
3. Secure the switch in some type of vise grips.
4. De solder the resistor from the LED and pull it back slightly (you will reuse same resistor for upgraded LEDs)
5. At this point check and see how the Stock LEDs are soldered to the switch and how they are connected together. ( You will be soldering the replacement leds in same way)
6. Easiest way to do it is to measure how much the Replacement LED legs needs to be cut, so they are all same length when replaced.
By the way on your new LEDs Short Leg will go to Resistor and Longer will be soldered to the leg thats is connected to the circuit board.
7. And now start Soldering !!! Solder everything back just like the stock LEDs.
8. You will need to use thin, but NOT sharp object to push the switch Lens with Numbers on it out to remove it. Use some Acetone or Nail Polish remover to "wipe off" Green backing on the Number Panel. It will come right off. Use Q-tip for this and only wipe off where the numbers are.
9. At this point you can re assemble everything back. Plug the switch back in and ENJOY the Awesome Red Color.
______________________
Some Pictures that will pretty much will sum it all up.
and DONE
ProdriveREX is offline   Reply With Quote
Old 04-09-2008, 07:46 AM   #2
Fav Mod: XM
Send a message via AIM to ebelp Send a message via MSN to ebelp
Default Re: How To: RED LED Upgrade for 04-05 HID Leveling Switch
Damn that looks good. Thanks for the DIY.
ebelp is offline   Reply With Quote
Old 04-09-2008, 08:42 PM   #3
Car: 05 CGM STI w/goldies
Fav Mod: Advan A048's
very nice!
crf-sti is offline   Reply With Quote
Old 04-10-2008, 03:09 AM   #4
Car: 05 Subaru WRX STi
Send a message via MSN to arnif
your led's are to bright...
arnif is offline   Reply With Quote
Old 04-10-2008, 05:07 AM   #5
HowTo Contributor
I like my buttons bright, Plus the picture does not completely resembles the actual look. It looks very nice, there is no bleeding to the other number, its nice and crisp.
If its too bright for you, that is why I indicated the range of brightness. You can get 20-30mcd LED and you will have very dim indicator if thats what you like.
