Old 04-03-2008, 07:16 PM   #1
Car: CGM 05
Fav Mod: IAG 38mm EWG
Send a message via AIM to 1loudsti
Default Super cheap Ipod mount
ok guys this is my first how-to so bare with me,i unfortunately didnt get many pics because i was doing this by myself but everything is pretty easy. this will work if you have a Ipod case with storage for headphones on the back, something like this
1: remove the shifter console enough to get the screws out of the center console, simply lift the back of the part at the rear of the shifter boot and pull up
2: remove the 2 black screws that hold the center console on, then gently (i hate this part) pull it off, there are 2 clips on the top that are stubborn
3: disconnect the climate controls by pushing the small tabs on the bottom of the connectors up and wiggling, then remove the black tube (it just pulls off carefully of course)
4: (optional) i removed my radio so i wouldnt scratch it and i had some more room, if you choose to do this simply remove the 6 screws and disconnect just the same as the climate control
5: you will now have a big hole there
i used a piece of cardboard to fabricate the shape i need before transfering it to sheetmetal
that is what my bracket looks like after paint, the large slot is cut to fit the rubber extension for the headphones on the back of the ipod
there it is mounted, if i had to do this again i would mount it a little bit lower because the potential is there for your keys to hit the back of it under cornering
just another mounted shot before putting everything back together, i used 2 of the screws for the radio to hold the mount on
after reversing the order you took everything apart you will end up with this:
just simply slide the ipod into the slot and plug it in!
now i just need to get my aux board and i will good to go!
1loudsti is offline   Reply With Quote
Old 04-03-2008, 07:27 PM   #2
Iron Fisted
Fav Mod: Sparco seat
Default Re: Super cheap Ipod mount
I just keep mine in the center console, but that's pretty aweseome!
Old 04-03-2008, 07:30 PM   #3
Car: CGM 05
thanks, i just cant stand rattles and **** so everything that stays in the car 98% of the time has a place
Old 04-07-2008, 01:21 PM   #4
Car: Steel Grey 06 STI
Fav Mod: Stage 2
i velcro'ed the back of my ipod's case and stick it in my glove box. But i do have an avic-d3 so i don't need to change my music with my ipod
aznboi320 is offline   Reply With Quote
