Old 03-31-2008, 07:53 AM   #1
Car: silver 05 wrx sti
Default uppipe Question
Is it possible to remove the stock uppipe without removing the turbo?
Moisti is offline   Reply With Quote
Old 03-31-2008, 07:57 AM   #2
Fav Mod: The Newest One!
Default Re: uppipe Question
I have read that it is if you are either removing or swapping headers. I have yet to confirm this. A quick search might get you the answer you are looking for.
Old 03-31-2008, 08:08 AM   #3
Car: 05 Aspen White STI
Fav Mod: Defi Gauges
Send a message via AIM to STI_Mike
it is possible but i also removed the header as well when i removed my uppipe.
STI_Mike is offline   Reply With Quote
Old 03-31-2008, 10:34 AM   #4
Is cuz I am replacing all the pipes my headers, uppipe and downpope and dont want to move the turbo if at all possible.
Old 03-31-2008, 10:36 AM   #5
Car: '05 Aspen White STi
Fav Mod: EQ Tuning tune
You don't have to remove the turbo. Just get some wire and hang it up right in its spot. I just did this this previous weekend so you should have no problems.
Old 03-31-2008, 11:08 AM   #6
I am going to try it I will see how it goes
Old 03-31-2008, 11:27 AM   #7
HowTo Contributor
Car: 06 STi
Fav Mod: 11.26 at 125.63
You have to remove your downpipe first to get at the uppipe bolts.
you turbo will stay put fine.
jasv11 is offline   Reply With Quote
Old 03-31-2008, 11:37 AM   #8
HowTo Contributor
Car: 2008 DGM (BBS+Navi)
Fav Mod: stock FTL?
There are brackets that support the turbo so you will be fine removing the downpipe and uppipe.
Remove the passenger side exhaust manifold elbow and you can get the uppipe out from the bottom. I usually remove the crosspipe as well for more room (and it's only 2 extra bolts.)
You will probably have the jack the engine up a little bit. Use a block of wood on the oil pan.
Old 03-31-2008, 12:00 PM   #9
I am pretty sure if you are taking the headers off then you do not have to take off the turbo. I am doing mine this weekend as long as it doesnt rain.
Header and up pipe install
Old 03-31-2008, 04:05 PM   #10
Car: My06 WRB w/ Gold STi
Fav Mod: JDM Headlights and JDM Rear Fog
If you are doing everything then it is so much easier if you remove the turbo. But if you just do the manifold then it is not necessary. I have done at least 30 manifolds and up pipes and the quickest times i have done are with the turbo off.
WRB Kid is offline   Reply With Quote
Old 04-01-2008, 12:54 PM   #11
HowTo Contributor
Car: 06 STi
Do not take off the turbo it is NOT necassary................god!
Old 04-01-2008, 01:08 PM   #12
i second that!
Old 04-02-2008, 04:43 PM   #13
Car: 05 STI
Fav Mod: urabus conversion
Send a message via MSN to aznpride75
no it is not necessary but i have hurd of some ppl doing it the only thing you have to worry about is when you go to take the up pipe out you might have to jack the motor up a few inches. also be careful of your valve cover seals there easy to hit and a pain in the you know what to replace
aznpride75 is offline   Reply With Quote
