Old 03-24-2008, 10:46 AM   #1
Car: STI's ;)
Fav Mod: Coolest Vendor Ever
Send a message via AIM to RallySportDirect Send a message via Yahoo to RallySportDirect
Default How To: 2008 WRX/STi Coilover Install
This is a how to install for 2008 Impreza Coilover install.
The factory suspension is very well designed, but as other previous models has room to improve on. And this is where the Cusco Zero2-E coilovers come in. They offer a great Daily Ride, and can be a powerfull tool at AutoX and Track Days.
Things needed:
Coilovers
Tools:
19MM Socket (6 point)
19MM Open end Wrench
12MM Open End Wrench
14MM Deep Socket
14Mm Open End Wrench
17MM 6 point Socket
17MM Open end wrench
Allen key to hold the sway bar end link from spinning.
Braker Bar
Torque Wrench.
And misc. extensions
1) Jack up the car, Put it on Jack Stands, and take off the tires.
2) Front Suspension is first. Take off the Brake line and the ABS wires off the Strut.
3) Take off the 2 lower bolts that hold the strut to the knuckle.
4)Take off the 3 top bolts that hold the top hats to the Chassis. Be careful, as the strut will be out after this. So make sure not to damage your outer axle boot.
New Vs Old
As you can tell the new coilovers are VERY low. We had to raise them about 1" to clear our race rims w/ tires. However with stock rims you might be able to get away with running the drop. But they are LOW!
5) Now go backwards. Put the top hat in so that the camber plate is sitting side to side. And tighten the top hat bolts.
6) Attach the Brake Line and the ABS wires to the strut.
7) Now insert the 2 lower Bolts to attach the strut to the knuckle. And Place the Camber bolt so that your tires to not rub on the strut. (Be careful, as this can ruin a brand new set of tires and coilovers very fast if not set up properly)
Rear
8) Rear is straight forward. Make sure that the rear sway bar is not attached to the suspension, as it will not allow the arm to drop far enough to get the stock strut and spring out.
9) Take out the middle bolt thats in the picture as that holds the strut to the lower arm. This thing is TIGHT! So a breaker bar and a 6 point socket are a MUST to not strip the nut!
10) Take out the trunk mat and the 2 plastic side pieces to expose the top of the rear suspension. The 2 plastic covers on the inside have tabs on the back of them that will need to be slid up to allow the Covers to come out.
11) Take off the 2 top hat bolts and the rear suspension will be ready to come out. At this point you will need to press the lower suspension arm down to give you enough clearance for the strut to come out.
OLD VS NEW
12) Now work backwards. Put the Top hat in place and tighten the 2 nuts. Then jack up the lower arm so that the new strut will go into the lower arm and insert the bolt. TQ spec for the lower arm is 100ftlbs according to a local tech. And now tighten the end links as well that you removed.
You are almost Done!
After you do all 4 corners make sure all the spring purges are tight, and that all the hardware(bolts) are tight to factory spec.
Lower the car and tripple check everything. Then slowly start doing figure 8's and listen for rubbing or clunking. If everything is ok, go and get a alignment ASAP!
Enjoy!
Kirill
RallySportDirect.com
RallySportDirect is offline   Reply With Quote
Old 07-03-2008, 08:28 AM   #2
Car: STI's ;)
Default Re: How To: 2008 WRX/STi Coilover Install
Lets bump this up to help people out.
Old 07-03-2008, 08:38 AM   #3
Car: 05 Subaru WRX STi
Fav Mod: Bilstein PSS9 Coilvers
Send a message via AIM to IUSTi
This needs to be added to the How To List. Great write up!
IUSTi is online now   Reply With Quote
Old 07-03-2008, 09:01 AM   #4
Car: 05 WRB STi
Fav Mod: I Heart Boobs
great write up. You make it so simplified I think my 10 year old brother could do it
Old 07-03-2008, 11:01 AM   #5
Car: 08 Gray STi
What'du use to raise it back up to clear your wheels?
Old 07-03-2008, 11:08 AM   #6
Car: STI's ;)
Its an adjustable coilovers. So you just raise them up
Old 07-03-2008, 01:25 PM   #7
Car: 08 Gray STi
Ah. Thanks. Good to know.
Old 07-03-2008, 03:10 PM   #8
I can't recall
Awesome write up. Will be looking at it more when I get some coilovers.
stealth is offline   Reply With Quote
