Old 03-22-2008, 01:47 PM   #1
HowTo Contributor
Car: 05STi - Meth Addict
Fav Mod: ze FP green
Send a message via AIM to ProdriveREX Send a message via MSN to ProdriveREX
Default Horn Hookup and Turn Signal Auto Canceling on Aftermarket Wheel *NRG Setup*
Well I have looked around and information is all over scattered in pieces.
Everyone have their own way of doing Horn and Signal on Aftermarket Steering wheel and Hub.
This is In My Opinion is the easiest and safe hookup of Horn and Auto Turn Signal Canceling on my 2005 STI.
Products Used:
1. NRG-F009 Steering Wheel
2. NRG SRK-250B Black QUICK RELEASE Kit Generation 2.5
3. NRG SRK-100H Short Hub
Here we go.
Horn Hookup:
All you need is 1 feet of 8 Gauge Wire and some zip ties.
You will find a Screw right under the steering column.
You will use that screw to hold the Red wire (brush) in place and also use couple Zip ties to set it in proper location.
When Hub is installed red wire have to be touching the Copper Ring in the back of the Hub.
You will connect GREEN/RED wire to your 8Gauge red wire that is touching the Hub. If in doubt test this green/red wire
by touching ground (metal steering column) - Your horn will signal with your ignition OFF.
Everything else is pretty straight forward. Here is some pictures.
Auto Turn Signal Canceling:
You Will REUSE the center insert of your Clock spring. You can take it out by prying off four tabs that holds whole Clock Spring together.
The Turn Canceling piece is little too large in diameter so you will have to wrap inside of the NRG hub with electrical tape.
Use about 10-15 full turns and check periodically how the Canceling piece fits. Once it fits snug I used a little bit of 3M trim adhesive glue
to make sure the piece stays in place and put some tape over it.
Take a note from the picture how it goes onto the hub.
Now Install your Hub, Quick Release and Wheel and ENJOY the Luxury of HORN and Auto Canceling Turn Signals. (and just forget about Cruise Control)
ProdriveREX is offline   Reply With Quote
Old 03-22-2008, 01:47 PM   #2
HowTo Contributor
Default Re: Horn Hookup and Turn Signal Auto Canceling on Aftermarket Wheel *NRG Setup*
Finished product Pictures. Enjoy.
Old 03-22-2008, 01:48 PM   #3
HowTo Contributor
A month later I ditched that weird shaped leather 009 wheel for 012 in Suede with red stiching. I couldnt get used to that weird shape. I guess I like my wheel Round.
Old 03-22-2008, 01:52 PM   #4
Car: WRB EDM 06 WRX STI
Fav Mod: Aerys 3"
thatīs better
torquemada is offline   Reply With Quote
Old 03-31-2008, 04:05 PM   #5
Car: CGM 05
Fav Mod: IAG 38mm EWG
Send a message via AIM to 1loudsti
sorry to bump an older thread but i did this and made the factory cruise work, just relocated it, pm me if you want to know how
1loudsti is offline   Reply With Quote
