Old 03-19-2008, 03:50 PM   #1
HowTo Contributor
Car: 06 STi
Default How To: DSS rear axle upgrade
Heres the tools you'll need
Start by cutting the bands off the boots
Slide the boots off the CV housing
Clean off the grease from around the inside of the CV bucket thats closest to the differential housing and remove the clip thats holding the CV together.
It looks like this when removed
jasv11 is offline   Reply With Quote
Old 03-19-2008, 03:51 PM   #2
HowTo Contributor
Car: 06 STi
Default Re: How To: DSS rear axle upgrade
Now that CV will come apart.....dont panic as the bearings will fall out when you pull it out....just don't loose any of them.
Now remove the clip with the clip remover tool and then slide everything off the axle
Once you have everything off the right side of your axle now you can put the axle nut back on the end of the axle as this is what you'll be putting in your vice to hold it.
This next part is kindof unprofessional but it worked for me.
Next you take your vise grips and clamp onto the axle and with your hammer wack the vise grips so that the axle pops out of the other CV casing. It takes a good wack to free it as it is held in with a c style clip.
Old 03-19-2008, 03:52 PM   #3
HowTo Contributor
Car: 06 STi
Once that apart take the DSS axle bar and grease it up and dont forget the clip, feed it into the CV making sure you dont catch the c clip and damage it.
Once thats popped in put your new boots on the axle like so
Now moove over the right side again and assemble the bearing collar over the axle then place the bearing stay over the axle shaft and put the clip on it to lock it on.
Place some grease that comes with the new axles into the CV housing first.
Place all the bearings back into the assembly. This is the tricky part.....you need to hold all the bearings in place then slide the assembly back into the CV....like so
Now your ready to install the large C-clip back together
Old 03-19-2008, 03:53 PM   #4
HowTo Contributor
Car: 06 STi
Pack both CV sides with grease supplied with the axles
Slide your boots over the CV buckets then with the clamps provided secure the boots firmly in place.
And all done.....now go clean yourself off
Old 03-19-2008, 04:00 PM   #5
HowTo Contributor
Car: 06 STi
If you need a how to for removing and replacing the axles you can find it here....
How To: Change rear axle
Old 03-19-2008, 11:18 PM   #6
Car: OBP STi
Fav Mod: really quick left foot & anything made my TIC
so should I be waiting to see some 1.5 60fts hahaha.
pharo is online now   Reply With Quote
Old 03-20-2008, 11:33 AM   #7
HowTo Contributor
Car: 06 STi
I sure hope so as long as the CV's hold up to the new 6 puck clutch I'm putting in...........the next weakest link
Old 03-20-2008, 02:46 PM   #8
Car: 06 BLACK STI!!!
Fav Mod: road head!
Send a message via AIM to all4bspinnin
nice, gj! hopefully i'll never have to change those...
what was the difference in weight between the dss and the stockers?
all4bspinnin is offline   Reply With Quote
Old 03-20-2008, 03:44 PM   #9
Car: 06 STi
Thumbs up Re: How To: DSS rear axle upgrade
Great how to. Thanks man.
Old 03-20-2008, 06:09 PM   #10
HowTo Contributor
Car: 06 STi
No problem,thanks
Not really noticable.....maybe 1lb at most, but I didnt really pay close attention.
Old 07-04-2008, 09:56 PM   #11
Car: 05 STi CGM Stg2
Hey nice write up....how did you know which boots went where...did they come with instructions?
