Old 03-19-2008, 02:59 AM   #1
Fav Mod: Starving my STI
Trader Rating: (12)
Default How do I remove the cam gears so I can remove the heads?
Do I need to get a special tool to hold the cam gear in place while I use a 10mm hex head to get the bolt off? I tried using an air gun but it just spins and spins.
It appears that I need to remove the cams to get access to the head bolts.
Old 03-19-2008, 07:04 PM   #2
Fav Mod: sz55 external wastegate
Default Re: How do I remove the cam gears so I can remove the heads?
check this thread out, towards the end STI Cam Sprocket/Gear Removal?? - Page 4 - Built Motor Discussion - NASIOC
Mycues1982 is offline   Reply With Quote
