Old 03-16-2008, 01:06 AM   #1
Car: 07 WRX STi
Fav Mod: ME! Track Time
Default DIY Camera Mount (youtube sample video included)
So I search around looking for a camera mount that would be safe to use for track days and but also something not too expensive. NASA rules require at least screw be used to mount the also tethered, from what i hear its got to be solidly mounted. I've looked at:
Camera Mounts - Sticky Pod, Grippers, Suction Cups, Light & Mid Weight Camera Mounts
dont' know if it pass tech inspection at the track plus kinda pricey
Sticky Pod Online Store
same as the gripper mount, don't know if it pass tech inspection
Building a Car Camera Mount
hmmm, may fit my needs and its cheap (this one got me brainstorming).
Also checked out the ioport mount but its more than $100...ouch! There's also the AndrewSS mount, but wanted something I can remove easily. I also have a HDD/SDHC hybrid camera so I wanted something with some sort of dampening. I will be recording through my SD media instead of my built-in hard drive.
Here's what I came up with.
Parts List:
  • Bogen-Manfrotto 482 Micro Ball Head (picked at local camera store for less than $40)
  • Nylon spacer (less than $1 at Home depot)
  • 3/8 16 2inch screw and nut (less than $1 at Home depot)
  • 2 3/8 washers (less than $1 at Home depot)
  • rubber bushings from kragen ($5, found in the help me parts section)
First, unbolt the center baby seat bracket
notice that the bolt is welded on
break it off or shear it off with a 17mm socket and a long breaker bar. I was able to break it off clean.
another shot from the top
assemble the screw, washer and bushing like so. Note that all the following picture shows a 2.5in screw, I actually used a 2 inch screw.
then stick it in the hole like this:
Then assemble the top side like this.
So the rear-deck is sandwiched between the two bushings.
Now put the nylon spacer over the nut and screw and ball-head in and now you're done. The bushing should help somewhat to isolate vibrations, compared to complete bolting everything down metal to metal.
Here the finished mount. Note that I have 2 nuts in, thats because I was using a 2.5 inch long screw. I now use 2 inch long screws so there's no need for the 2nd nut. This adds some clearance from the top of the camcorder and the rear windshield.
I'll post some mounted pics and test drive video later.
***Here is a sample track video with this mount:
YouTube - HPDE1 at Infineon 4-19-08
henjiro is offline   Reply With Quote
Old 03-16-2008, 06:05 AM   #2
Car: 04 Platnm Silvr STi
Fav Mod: GT35R 450WHP Pump No Meth
Default Re: DIY Camera Mount
Pretty sweet idea, post it in the DIY section. I have the Andrewss mount and it works excellent. You can get the 2part one that easily removes the top section so it is no longer noticeable.
Old 03-16-2008, 07:35 AM   #3
GUNNIN' IT
Fav Mod: Sparco seat
I'd personally rather get the AndewSS mount, but this is a nice option.
amg destroyer is online now   Reply With Quote
Old 03-16-2008, 06:54 PM   #4
Car: 07 WRX STi
re-did some stuff, no spacers used and also added the plastic cover back in.
This is how it would normally look when its not in use.
mounted pics
Old 03-16-2008, 06:58 PM   #5
Car: OBP 07 STi
Fav Mod: Ring-Shaped Reinforcement Frame
^^^^^^ very nice work.
Old 03-16-2008, 07:54 PM   #6
Car: 07 WRX STi
test run video:
YouTube - my DIY camera mount test
Old 03-16-2008, 08:23 PM   #7
Car: 07 SWP STi
Fav Mod: Perrin Exhaust
this is awesome!
Dragicon is offline   Reply With Quote
Old 03-16-2008, 08:24 PM   #8
Car: 07 SWP STi
Originally Posted by henjiro View Post
i could only take about 30 seconds of this most boring in car video evar!
Old 03-16-2008, 08:58 PM   #9
Fav Mod: Tires and Brakes!
Possibly my next mod now! ! !
gosu is offline   Reply With Quote
Old 03-16-2008, 09:07 PM   #10
Yeah definatly. Very effective little piece, nice work man!
Old 03-16-2008, 09:39 PM   #11
Car: 07 WRX STi
of course it'll be boring. i wouldn't do anything stupid on the street. anyways, just showing how it would be on rather rough roads...roads in the bay area really sucks.
Old 03-16-2008, 11:14 PM   #12
Car: 07 WRX STi
I also noticed that the tighter I screw the top nut, the stiffer the assembly gets (more vibration transmitted). so kinda acts as an adjuster. So for people who doesn't need dampening, you can make it really stiff. I'm refering to the nut in this pic:
Old 03-26-2008, 07:42 PM   #13
STI Guru
Fav Mod: Whooshing sounds
Is it really necessarry to prey the welded piece or is there a way around it?
I just got my sunpak mount in the mail.
Old 03-26-2008, 08:32 PM   #14
Car: 07 WRX STi
It has a different thread size than the mount I am using. . Unless your mount uses the same size or you can find an adapter of some sort, you wouldn't have to.
Old 04-13-2008, 11:42 PM   #15
Car: 07 WRX STi
Default Re: DIY Camera Mount (youtube sample video included)
I was at Infineon this weekend and finally tested out my mount. Worked out pretty good IMO. Here is the video:
