Old 03-10-2008, 11:09 AM   #1
Default Ball Joint Removal... Need Help
I was able to seperate the ball joint from the control arm easily with a ball joint remover. BUT, I'm having a hard time removing the ball joint itself from the hub knuckle. I've tried banging a chisel into the slit in almost every direction to open up the knuckle in an attempt to free up the ball joint. No luck at all, while going through this I mangled the ball joint beyond manglement. I really don't care, I'm replacing them with WL's, I just want to get them out.
PB Blaster doesn't seem to be blastin' either, just making more mess to clean up.
BBKG79 is offline   Reply With Quote
Old 03-10-2008, 01:57 PM   #2
Default Re: Ball Joint Removal... Need Help
It's looking like I'm going to have to remove the axle or axle boot off of the hub in order to get a straight shot with a chisel or screwdriver in the split to knock the ball joint out.
This is all new to me so I have no idea how to remove that, it's not clear in the manual.
Someone I know suggested using a torch to heat up the knuckle, but changed their mind in fear of hitting the axle boot.
I came across TIC's tips for this on Nasioc, but I have no idea what a bearing puller is or how to use it. When I did a google there were several different ones. Not sure which one to choose, plus I'll need a BIG FREAKING HAMMER Hopefully Clint will chime in...
Old 03-10-2008, 04:05 PM   #3
Fav Mod: sz55 external wastegate
I think u need to remove the balljoint from the hub first before removing it from the control arm with alittle prying action
Mycues1982 is offline   Reply With Quote
Old 03-10-2008, 05:10 PM   #4
Fav Mod: Driver weight reduction
Try this...
Loosely screw the ball joint back onto the control arm and pound on the control arm with a rummer mallet to get the joint it out. If you already stripped the threads, use vice grips to hold it.
Good2Go is offline   Reply With Quote
Old 03-10-2008, 09:40 PM   #5
Originally Posted by Good2Go View Post
Try this...
Tried that, did not work. Why? Because the ball joint was rusted in. There was NO WAY I WAS GOING TO GET IT OUT.
End result - I had to remove the caliper, take the rotor and hub off completely. Put it in a vice and use a long steel chisel like screwdriver to bang it out. I'll post pics later today, just finished this about an hour ago.
This is an 05 with 35k on the clock, I suggest to anyone else doing this mod to have it done professionally. Unless you have plenty of resources and tools. The aggravtion isn't worth it.
I can't understand how it could be rusted in there like that. I mean you see this kind of stuff on older cars like 1920 - early 90's.
Can someone explain how this happens on newer cars? Is it cheaper/lower grade metals that are not coated to prevent rust?
P.S. I have an appt thursday for an alignment, eff that I'm letting them do the other side
