Old 03-03-2008, 04:39 AM   #1
Car: 2004.5 Subaru WRX ST
Fav Mod: 17x10s
Thumbs up How to: Install t-stat on Process West Oil Cooler
The Process West peice is a fanastic bit of kit, but it doesn't come with a thermostat for the oil cooler. Some research found a Perma-Cool inline t-stat for ~$40. The 1/2"NPT barbed hose fittings are a $4 each. Hose clamps, and about 20 minutes on the garage floor is all you need for an easy solution.
Start by cutting the rubber hoses:
The hose facing the FRONT of the car is the supply hose. This is important based on the inline thermostat from Permacool having specific feed line.
Here is the t-stat itself, with the barbed fittings taped up, and the hose clamps ready:
The center section of the Permacool t-stat has a "plunger" that slides to open/close access to the oil cooler itself. It doesn't fully open/close, allowing some oil to circulate to the cooler to prevent cold oil shock or air pockets.
The Process West kit uses a bracket to align the hoses and hold them on their way up to the oil cooler. There is a threaded nut welded to the bracket. I slipped a stainless steel zip-tie through the hole and around the thermostat. This picture is from above, looking down at the Process West bracket, seeing the zip-tie and down at the thermostat:
The zip-tie couldn't be pulled hard enough to (IMO) properly secure the thermostat in place. I then wrapped a hose clamp around the whole assembly, and tightened it down, and the peice is as solid as a rock. The hose clamp secures the location, and the zip-tie makes sure it stays on the bracket.
Here's the final picture showing the hoses on the barbed fittings, with hose clamps, and the large securing hose clamp holding the whole assembly in place:
So, under $60, and about 20 minutes of time. Easy to cut the hoses, and reuse the PW bracket. The thermostat sits about 3/8" above the subframe which doesn't make it a problem clearing speedbumps or anything.
Thanks for reading.
loworbitSI is offline   Reply With Quote
Old 03-03-2008, 10:10 PM   #2
Car: 04 STi WRB
Fav Mod: Driver's school
Send a message via AIM to Splash Send a message via Yahoo to Splash
Default Re: How to: Install t-stat on Process West Oil Cooler
nice job!
Splash is offline   Reply With Quote
Old 03-05-2008, 04:42 AM   #3
Car: 06 STi
Great write up. Thanks and cheers.
Old 06-26-2008, 07:01 PM   #4
Car: 04 WRB sti
Fav Mod: AVIC D3
Im planning on doing a oil cooler on my car also. Can I ask what the importance of the thermostat is?
SR20steve is offline   Reply With Quote
Old 07-01-2008, 06:46 AM   #5
Car: 02 WRX
Fav Mod: pegs, shocks
A thermostat in an oil cooler serves the same purpose as it does for a radiator. It stays closed until a certain oil temperature, then opens to allow oil through the cooler. this prevents an "over-cooling" of the oil.
Imagine it's below zero and you're driving around with oil flowing freely through the cooler...you'd have some difficulty getting the oil to operating temperature.
ManbIKE26 is offline   Reply With Quote
Old 07-01-2008, 03:54 PM   #6
Car: 04 WRB sti
Fav Mod: AVIC D3
Cool thanks, makes sense. But for my climate it never even gets to freezing, so I think I can get away with not having one.
