Old 01-15-2006, 08:41 PM   #106
Car: 05 Subaru WRX STi
Originally Posted by JRsti
The passenger side is 1/2 inch higher than the driver side. The driver side is 26 inches high the passenger is 26 and a 1/2. That bothers me.
Hmmm...not sure if the difference on mine is the around the same or not. I am a little bothered by it too, but after a year, I haven't seen any other changes aside from my camber in the rear but that's another issue.
rasetsu is offline   Reply With Quote
Old 01-16-2006, 07:12 AM   #107
Car: 2oo5 cgm STi
^^^ mine is like 1/4" - 1/2" higher on the passenger side as well. Its just how the car is.
Old 05-18-2007, 09:31 AM   #108
Car: 05' STI
Fav Mod: Defi gauges, or TXS TBE or JDM sidemarkers...arg!
Arrow Re: STi pink spring installation procedure and pictures!
What about trimming of bump stops?
I remember seeing in another thread that users cut the bump stops...
-Nigel
NewShockerGuy is offline   Reply With Quote
Old 05-20-2007, 04:52 PM   #109
Fav Mod: XM
Send a message via AIM to ebelp Send a message via MSN to ebelp
Default Re: STi pink spring installation procedure and pictures!
Originally Posted by ONEQUIKSTI
I installed the JDM pinks, Group n mounts (very happy with the performance), but I still get a clunking sound fronm the front and rear of the car whenever I drive very slow in a parking lot with bumps, etc.....any ideas??? I have read numerous posts on here about other people with the same problem!!!
When you say "clunking", that sounds like a strut problem, rather than a spring problem.
ebelp is offline   Reply With Quote
Old 06-26-2007, 10:35 PM   #110
Endlinks? My stock endlinks make a loud clunk whenever I went unevenly over a bump or even on slow turns onto the driveway and so forth. Kartboy endlinks took away the noise.
yuantrouble is offline   Reply With Quote
Old 08-24-2007, 07:31 PM   #111
-Nigel
How to trimp/cut/replace bumpstops?
luckie8 is offline   Reply With Quote
Old 08-24-2007, 08:50 PM   #112
Car: 04 psm STi/Tuned by
Fav Mod: all of em'
Send a message via AIM to Spec_C Send a message via MSN to Spec_C
great writeup!! i'm going to be doing this in a few days and this will be very helpful. intalling jdm pinks, whiteline front/rear sways, endlinks, steering rack bushings, and anti lift kit.
Spec_C is offline   Reply With Quote
Old 08-29-2007, 01:09 PM   #113
great write up thank you
oldasdirt78 is offline   Reply With Quote
Old 09-12-2007, 08:09 PM   #114
Car: 05 Subaru Wrx STI
Fav Mod: Greddy Tic
After the springs set in how was the ride. Was it looser or stiffer? How many inch drop did it give u over the stock springs?
harout18 is offline   Reply With Quote
Old 10-28-2007, 06:42 AM   #115
Car: 07 UGM STi
Fav Mod: Aux cord & Nitrogen in tires
Is there a new thread or a better thread w/ pics?
AP1toGDRev.G is offline   Reply With Quote
Old 10-28-2007, 08:12 AM   #116
Car: 2oo5 cgm STi
Here is mine. http://www.iwsti.com/forums/how-inst...tallation.html
Old 11-21-2007, 10:55 AM   #117
Car: 07 UGM STi
Originally Posted by austinpike View Post
austinpike's thread is the best I have found so far. Thanks man
Old 11-23-2007, 08:54 AM   #118
Car: 07 Black WRX STi
question:
If you lower your ride height do you need to buy top camber plates? or can the stock camber bolts adjust for the lower springs?
If top camber plates are required would i only need them for the front or back or both?
I'd hate to buy some springs and go through a set of tires in 5,000 miles
syswolf84 is offline   Reply With Quote
Old 12-05-2007, 05:50 PM   #119
Car: 07 Subaru WRX STi
Fav Mod: Stage 2 :D
Originally Posted by syswolf84 View Post
question:
I lowered my car with RCE yellows (lower than the pinks), and the MOST camber I could get out of the front was still -1 degree with the bolts maxed out. Camber wont' be an issue with the pinks, unless the problem is that you can't get enough negative camber. If you want to go MORE negative, like -2, you will need camber plates.
Either way, after putting them on, pay to have a performance alignment done to the car.
holycow is offline   Reply With Quote
Old 04-10-2008, 08:04 PM   #120
Car: 2005 WRX Stage 2
great write up.
plac is offline   Reply With Quote
