Old 08-04-2005, 08:59 PM   #91
Fav Mod: sz55 external wastegate
I just realized that I forgot to transfer over the plastic sheething that sits on the spring towards the bottom, do you think I will have any problems from not doing so? Thanks also for the great walk through, helped me alot
Mycues1982 is online now   Reply With Quote
Old 08-04-2005, 09:08 PM   #92
jenner
Posts: n/a
Why would you need to transfer it over. Your JDM pinks should have come with it. I guess I am assuming you installed pinks vs some other aftermarket spring.
In any case the plastic sheething keeps the metal coils of the spring from directly compressing and contacting each other. The prevent noise and chipping of the paint on the spring.
Old 08-04-2005, 09:40 PM   #93
Rev
STI Guru
Car: 06 V70R
Send a message via AIM to Rev
Put back the rubber black sleeve. Im guessing you're talking about the rear struts? I think it is there to avoid abrasion between the spring and the strut
Old 08-04-2005, 10:55 PM   #94
I actually installed Tanabes and noticed the plastic coil sheething on the lower part of the spring in the photo of yours and realized I didnt transfer it over from the stock spring. I hope it doesnt create a problem, but I doubt it will. Was just asking your opinion about it.
Old 09-19-2005, 01:57 PM   #95
Rev
STI Guru
Car: 06 V70R
If you struts get wet or you drive through rain, yes it will create a problem, you'll get strut piston stiction issues (also known as strut clunk) ...
Old 12-30-2005, 07:54 AM   #96
www.Subie.tv is niiice
This really helped me guys! Thanks. I have to put my stock suspension back in the car. I purchased some other stock suspension and by using your pics I was able to identify what was missing. Thanks.
Old 01-14-2006, 10:19 PM   #97
Car: java/black 04 STI
Originally Posted by StrikTerorInst
I just have a question about clearance on both sides of the vehicle. I just installed the pink springs and group N mounts, but somehow both wheel wells on the passenger side sits higher...what could be the cause of this. I didn't install the springs myself but from a local shop. Thanks
I have the same problem... I checked the perch and three holes on top of the perch are facing out. But the rear passenger clearance is ok. I only have the problem with the front passenger side. What else can I do?
JRsti is offline   Reply With Quote
Old 01-14-2006, 10:38 PM   #98
Car: 05 Subaru WRX STi
My driver's side sits a little lower than my passenger's side too. I think it's part of the characteristic of the car.
rasetsu is online now   Reply With Quote
Old 01-14-2006, 10:59 PM   #99
The passenger side is 1/2 inch higher than the driver side. The driver side is 26 inches high the passenger is 26 and a 1/2. That bothers me.
Old 01-15-2006, 01:00 AM   #100
Car: '05 STi OBP
Fav Mod: EcuTek!
Send a message via AIM to Deviancekicksin
I just bought a pair of used Pinks and the plastic coil sheething on mine is coming off... What kind of glue would be appropriate to use? I'm thinking about something that will stick well, and endure the elements.
Deviancekicksin is offline   Reply With Quote
Old 01-15-2006, 07:19 AM   #101
Rev
STI Guru
Car: 06 V70R
Glue?
You mean the coil protector on the back springs, right?
Good question. I dunno, I would find some kind of a wide rubber hose, split it in half and kinda 'wrap' it around the coils like in the photos ..
Old 01-15-2006, 10:06 AM   #102
Car: '05 STi OBP
Fav Mod: EcuTek!
Originally Posted by Rev
Glue?
I am talking about the grey protectors on all the springs.
They are held on by glue and one of them is a lil loose...
I think some krazy glue or something might do the trick.
Old 01-15-2006, 10:23 AM   #103
Car: 2oo5 cgm STi
the stuff holding it on there is kind of a rubber cement; whatever you use should be somewhat flexible since the spring is (obvioulsy) flexing all the time and the metal and plastic will contract differently depending on the temperature. krazy glue is too rigid.
Old 01-15-2006, 01:30 PM   #104
Car: '05 STi OBP
Fav Mod: EcuTek!
you beat me to it. Upon further inspection I did notice that it was a rubber cement type of adhesive. Now I just need to figure out what is the most appropriate to use.
Old 01-15-2006, 01:49 PM   #105
Car: 2005 Subaru WRX STI
I installed the JDM pinks, Group n mounts (very happy with the performance), but I still get a clunking sound fronm the front and rear of the car whenever I drive very slow in a parking lot with bumps, etc.....any ideas??? I have read numerous posts on here about other people with the same problem!!!
ONEQUIKSTI is offline   Reply With Quote
