Old 02-18-2008, 08:06 AM   #1
STI POWWA
Car: 06 Subaru WRX STI
Fav Mod: My 20g
Default Maddad guauge install with oil sandwich what went wrong.
Ok guys take a look at the pics what in the hell did I do wrong. I did an oil change on my car when I put the sandwich adapter on. Mobil 1 syn. with new filter of course. everything seems tight (double checked) well no leaks just sitting there I crank the car and cut it off about 30 sec. later and the thing is peeing oil out of the sandwich adapter were the threads are the the brass bung for the oil temp. There are four holes did I put it in the wrong one?
should I had used some type of thread locker? Help please. I had to drain the brand new oil and put new oil in with a new filter just to make sure I got no containments in the engine.
diabloadsit is offline   Reply With Quote
Old 02-18-2008, 08:09 AM   #2
Fav Mod: CAR LIFT & Protune!
Default Re: Maddad guauge install with oil sandwich what went wrong.
yes use thread sealer...
Old 02-18-2008, 08:16 AM   #3
STI POWWA
Fav Mod: My 20g
What type should I use. Your not talking about Loctite are you?
Old 02-18-2008, 08:22 AM   #4
Car: cars, pball and all
Send a message via AIM to awdrev
i have the same sandwich...... where's ur rubber gasket?
the other holes need to be plugged with the plugs that came with....use teflon in EVERYTHING, of course u need a thread sealant!
awdrev is offline   Reply With Quote
Old 02-18-2008, 08:22 AM   #5
loctite would work, ive used plumbers teflon tape on my installs, just make sure you leave the first 2 or 3 screw things without tape, (as they will be in contact with the oil).
Old 02-18-2008, 12:40 PM   #6
STI POWWA
Fav Mod: My 20g
I have the rubber gasket just not in the pics.
Thanks for the info guys.
Old 02-18-2008, 12:41 PM   #7
STI POWWA
Fav Mod: My 20g
I don't understand why they didn't do the NPT threadings on these things so you wouldn't have to worry about sealing it.
Old 02-18-2008, 01:25 PM   #8
Car: 06 Subaru WRX STi OB
Fav Mod: Upgrading 04 WRX Wagon to 06 STi
I did not use any sealant, and I have both oil temp and pressure. I get minuscule seepage from the temp sensor, but none from the pressure sensor. I will pull mine out and seal them on my next oil change. Could you have possible cross threaded or stripped the threads? I know it was a really tight fit and i though i was going to break them. Actually looking at your pics again, looks just like mine.
god5337 is offline   Reply With Quote
Old 02-18-2008, 02:36 PM   #9
STI POWWA
Fav Mod: My 20g
No, I checked for cross threading. I tightend more before takening it off and help to a point it was just sipping. I will but it on when I change my oil next time again. This time I will do the sealant and see how it goes from there.
Old 02-21-2008, 08:27 AM   #10
Car: 06 STi
Plumbers tape and a little bottle of stuff called IndianHead thread sealer. Will never leak or rotate/vibrate loose, ever.
neverendingmods is online now   Reply With Quote
Old 02-21-2008, 12:52 PM   #11
STI POWWA
Fav Mod: My 20g
How about plumbers tape and some Red Loctite.
Old 02-21-2008, 06:59 PM   #12
Car: 05' OBP
Fav Mod: Trunk debadge
Bronze SEMA 2007 Sponsor
you'll never get it off again, well you might get it off but not without screwing something up...
nemisisSTi is offline   Reply With Quote
Old 02-27-2008, 08:44 AM   #13
Car: Family, Car.
Fav Mod: Anything MadDad
We spec out 1/8 NPT for our oil temp, water temp, and oil pressure sending units. That said it's still a good idea to use a teflon tap on upper most threads. I've used a drop or two of Permatex Threadlock Red but literally 2 drops on the top most threads to ensure it doesn't seep into the oil/water.
R.
daddysscp is offline   Reply With Quote
